Threads: 51
Likes Received: 123 in 88 posts
Likes Given: 164
6 How do I set up I-BUS for my Flysky i6? Do I need to change any wiring from PPM? I want to try it out, but can't find any useful information. Thanks!
Threads: 30
Likes Received: 1,199 in 755 posts
Likes Given: 714
45 I-BUS and PPM are just different signal delivery protocol (I-BUS/SBUS is faster). It will depend on what receiver you are using as some are only pwm & ppm and some are also I-BUS capable. Which receiver do you have?
Threads: 51
Likes Given: 164
6 Just figured it out the other day! You need to solder the pin into one of the FC'S UARTS, and then enable Serial Rx on the UART in Betaflight. Also, I needed to switch the PPM wire on the Rx from PPM to the servo I-BUS. It works like a dream now!
Threads: 30
Likes Given: 714
45 Excellent! Now go punch some holes in the clouds!!!!
