The market for quadricopters is super saturated. We also find there many brols that hyper elitist machines. But it also allows for good discoveries as Hubsan H109s X4 pro.
Presentation
The Hubsan H109s X4 Pro is a quadricopter for shooting for amateurs. It is equipped with a video feedback system nonproprietary type of 5.8GHz. This means that with any 5.8GHz receiver connected to a screen or glasses, you can experience the flight immersion (FPV). The device is equipped with GPS makes its secure travel and, if you can no longer see the direction of your movement when you fly in sight, just remember it at its takeoff point.
Camera
The camera for shooting to record at a resolution of 1080p at 30 fps through a 12-megapixel sensor. No adjustment is possible from the camera. The connector Mini USB Type.
The camera stand unflinchingly accept any other type of GoPro camera format. Note, also, that a nacelle model for smartphone comes with.
In the "advanced" version, the pod of the camera is a type of boat 3 axes, unlike the one I received is a model 1-axis.
Drums
The battery type is a classic LIPO battery 7000mAh 25C 11.1V. The balancing connectors are JST and those of the supply XT60. The battery design is nothing special, it remains in the middle of the model for all.
Remote control
The remote is very comprehensive and will prevent you from going through a smartphone or tablet further, reducing the weight of the hands, firstly, and, secondly, also limits your investment in case your tablet or smartphone is declared obsolete.
To replace the rechargeable batteries, I decided to place a LIPO 1000mAh 3s. The XT60 sheet was replaced by the one on the battery holder.
Connectors
The video connector is a RP-SMA and receive a stick-type antenna. We also note a micro-USB for the updates.
Below you will have access to the connectors on the device. Sheet for video and USB supply 12v for a parachute or other type of accessory.
Measurements and Testing
- Diagonal: 370mm
- Weight: 1006g
Video
Conclusion
The device is, in my opinion, very good at this price range. I just searched on the net and I have not found equivalent except at Xiaomi MI drone. The fact of not having to use an application of the brand also limits the risk to have to move with all kinds of accessories.
Autonomy is more than correct and batteries are easily found on the Internet.
The downside is the car, which alone takes all the fun of this device. If you buy it, I can only advise you to take a type of boat 3 axes like thisHAKRC Storm32 3and you print it supportrequired for attaching the nacelle on the X4.
I recommend this quadricopter for a first purchase. If you want to acquire good habits before switching to a more expensive and more powerful machine, then the Hubsan H109s Pro X4 is for you.
The device is available hereHubsan H109s(Coupon: "Didhubsan")
Good flights!
Presentation
Camera
Drums
Remote control
Connectors
- Diagonal: 370mm
- Weight: 1006g
Video
Conclusion
Good flights!
