HSKRC ESC 45A 2-4S BLHeli-S DSHOT600
Hi everyone,
i am building my first 250mm FPV quadcopter;
i found  these ESCs on bangood:
https://www.banggood.com/it/HSKRC-Brushl...mds=search
Have you ever had experiences with these? Do you think it is a good idea to buy them given the price?
Thank you so much guys!
HSKRC (not to be confused with HAKRC who have a similar name) are generally known as a cloner of other manufacturers frames so who knows how good their electronics are. Those are likely a clone of another manufacturer's ESC as well.
Most people tend to buy 4-in-1 ESCs these days and there is a limited market / user base for single ESCs so you might struggle to anyone on here who has used these particular ESCs, especially from a manufacturer who doesn't have a known track record of producing good quality / reliable electronics.
So I think it will be a case of pay your money and take your chances.
(04-Jul-2022, 09:41 AM)SnowLeopardFPV Wrote: HSKRC (not to be confused with HAKRC who have a similar name) are generally known as a cloner of other manufacturers frames so who knows how good their electronics are. Those are likely a clone of another manufacturer's ESC as well.
thank you so much for your answer.
I have two FC: MATEK F405 STD and naza V2.
I didn't want to throw away the naza V2 so I decided to test its stability on a quad 250 and then maybe switch to the F4 in case I didn't have enough fun.
The problem is that I don't know if there are ESC 4 IN 1 compatible with both FC. I have never seen a naza with a 4 in 1 esc.
What do you think?
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 292 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 143 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 216 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 269 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 160 10-Mar-2024, 02:09 AM
