Threads: 23
Likes Given: 56
8 Great idea, the only OSD feature I'd use is battery voltage.
Current quad: ZMR 250 / DYS SE2205 / Littlebee 20A ESCs / Drone Lab 1500 4S / Naze32 Rev5 / BF 2.7.1
Check Out My Build<<<<<<<<<<
Threads: 83
Likes Received: 533 in 271 posts
Likes Given: 498
30 Game changer right there for me, a simple OSD is all I want anyway.
Threads: 672
Likes Given: 2,027
139 very neat solution indeed!!
Threads: 1
Likes Received: 7 in 4 posts
0 I believe they are about to release a new version of this with better osd options.
Threads: 22
Likes Received: 27 in 12 posts
Likes Given: 1
0 By default, the current version displays the camera input power voltage on the OSD. However if you are using a BEC/regulator to power camera, voltage reading will be the regulator output. The HS1190 has a separate input available that needs to be soldered to unregulated voltage. I'm disappointed it did not just comes with a plug and 2 wires for that.
Threads: 76
Likes Received: 191 in 85 posts
Likes Given: 39
16 Yes they are releasing a fix for this. In fact one of our local shops is offering to do recalls for anyone who purchased the hs1190. Apparently they are replacing all the ones that broke since they were instructing people to power it direct from the lipo.
The better way to set it up is to remove the back plate and solder in the included wires on to the vbat connection on the camera's board. Just to be extra safe, put a 1000uF 35v low esr cap on your lipo connection.
