05-Jul-2018, 06:58 AM (This post was last modified: 02-Aug-2018, 08:03 PM by trojanGoat. Edit Reason: added some info )
Howietzer Project
I've been racing for over 3 years now and at this point I've collected a LOT of frames. Some of them are obsolete and others are still hot on the market. In a racing scenario, it's difficult to compete when all your quads are using different frames. This means a large change in weight, PIDS, props and stockpiles of spare parts!!. I wanted to take a step towards standardizing the frames I'm using. Since I'm not sponsored, it would have cost a lot of cash to order 6 frames + spare parts. It's not terribly difficult to design drone racing frames so with the help of a friend I ventured into the "Howietzer Project".
Why another frame?
There's so many already, I know. The idea behind this frame is to keep it affordable, light, rigid, durable and better than other racing frames. Parts shrink and change almost on a weekly basis and I wanted to be able to easily adapt and keep the costs low when updates to the design is needed.
Aluminum standoffs get warped, bent, stripped and dislodged. Broken standoffs also tend to cause fractures on the carbon fiber it's mounted on. In order to keep the frame rigid and strong we decided to use carbon fiber spacers instead. I'll be surprised if anybody manages to break these.
Yes, It has a pod.
Nylon pods can be boiled in water with dye for half an hour. The boiling process rehydrates the nylon and actually makes the pods a lot more resistant to fracturing and breaking.
We created a multi-functional pod that sits on top of the frame. The pod is easy to mount since it only uses 4 screws. There's plenty of space for your vtx, rx, camera and maybe even an on-board DVR. The stl files are available on line, feel free to modify it to your needs. TPU works well, but we found that Nylon seems to work best to keep your electronics safe.
The pod looks like a shark fin, shark tooth, wizard hat or whatever floats your boat I suppose. It has a tall pointy top to aid you in turtle mode over tall grass and aerodynamics on those full throttle sessions.
But wait, there's more....
The arm's bolt pattern matches the floss v1 and v2 (not 2.1). That's right, you can directly swap arms with one of the most popular frame out there. The floss arms tend to get soft after a few crashes and causes hot motors. Pictured above, I decided to swap out the stock 4mm arms with the Howietzer's 5mm arms.
4 bolts will remove the pod giving you room to service your machine. The quad on the left is using the Airbot Firework FC with a gigantic gyro on top. This might be difficult to fit in a standard frame, no issues here. The quad on the right is the LUX v2 F3 (and one of my favorite flight controllers). There's plenty of room for other electronics in there. Since the top is hollowed out, you can easily add and remove parts.
Similar to the Martian Frame, the arms have a small hollow extrusion to prevent motors from hitting the ground during a crash. Some pilots are very keen on having clean builds. It's possible to run the TBS Race wires under the arms. Motor wires can be mounted backwards away from the FC for a very clean look and easy access to motor solder joints.
Profile pics:
Picture on left is the low profile setup for an AIO with ESC integrated (Asgard). There's 10mm space, enough room for the FC & battery strap.
Picture on right is the taller profile setup that uses 4 extra spacers. There's 15mm space, enough room for FC, 4in1 ESC & battery strap.
Howietzer in action:
This frame is awesome, How can I get one?
Since this frame has an uncanny resemblance to the Merica frame and we want to avoid any drama that might arise from this issue, this frame is now OPEN SOURCE! If you want to try this frame you can do 1 of 3 things:
1) Private message me and I will put you on a wait list. I will only order these in batches of 10 otherwise it will cost too much.
Price:
- $32 frame & hardware
- $4 3d printed pod
- $10 - $20 shipping (depending where you are)
2) You can order the frame from Armattan Productions. Just a warning, they do not have proper lengths for the screws. Howietzer @ Armattan Productions
3) You can download the files from GitHub and order the CF frame yourself. I ordered a few batches already from www.cncmadness.com They are great to deal with and their CF quality is amazing. The more you order, the cheaper it gets. If you are ok with slightly lower CF, you can get it cut in China for a much cheaper price.
If you choose to go ahead and cut your own CF, each frame consists of:
- 4 x 5mm arms
- 8 x 5mm spacers
- 1 x top plate
- 1 x bottom plate
You will also need some hardware listed below:
- 4 x 25mm m3 screws
- 4 x 22mm m3 screws
- 8 x m3 locknuts
- 4 x 25mm m3 nylon screws
- 8 x m3 nylon nuts
Join the project:
If you would like to make contributions to the project and make design changes, please visit:
Donations:
We are making zero profits from this frame. Your donations can help us make more improvements to this design.
Email:
