Threads: 5
Likes Received: 1 in 1 posts
0 Hi Guys, so I have an Aaris explorer 280 long range 5" freestyle quad flashed with iNav. After a crash one day the front right motor quit working. I ordered an esc but swapped it out to no effect. I just got a new motor in and same thing. Before I installed the motor the old one would occasionally randomly give the last 2 beeps and start turning but sounded really loud almost like it was grinding. I'm well trained on how to use a multimeter as it is one of my most used tools at my day job. I'm just not sure what to even test to figure out where the voltage starts/ stops and what V it should be reading. Does anyone have any tips on how to troubleshoot these issues with a meter or possibly in iNav? Any suggestions would be greatly appreciated.
Threads: 119
Likes Received: 829 in 674 posts
Likes Given: 132
20 To trouble shoot this issue.. first check the motor screws with the multimeter.. see if any of them have continuity to any of the esc / motor wire pads.. they should not.. if u do.. ur motor screws are contacting the windings (some motors u can’t see under them)..
Take the new esc and install them on the quad in a location you KNOW. Is good.. check it first and confirm.. if the new motor/esc works as it should .. it will be a fc issue
Threads: 5
0 UPDATE: Now when i power up fc the #2 motor consitantly issues the last 2 beeps about 20 sec after the other 3 motors and then spins up at full RPM. Any thoughts? Anyone?
