How to test Taranis TX range
How do I a range test with the taranis x9d plus on the bench? I searched for YT videos on the procedure but did not find anything useful, just people flying/walking away from the craft with the tx on their hand to see when they lost RSSI.
I ask because I changed my radio broken antenna. SWR is mostly 0 and sometimes 1.
Right next to the bind option in the menu you'll find range mod. When in range test mode the output power is 1/30th of the normal power.
Hit that and Walk away.
When you hear telemetry lost you have exceeded the range.
So the real range is roughly the range you got * 30.
You can't do a range check on the bench. You need distance!
If your SWR reading keeps jumping between 0 and 1, you have a problem somewhere. Either the antenna connection, the connection to the antenna pigtail inside or a problem with the RF output stage of your taranis.
If your previous antenna was broken and you had the radio turned on with a broken antenna, there's a good chance that you could damage the output stage of the radio's transmitter.
  Poor range and sudden loss of control with TBS CRSF husafreak 22 1,073 04-Mar-2024, 05:54 PM
Last Post: husafreak
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 160 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  ITElite DBS ITE-DBS02 Range Extender PJKMBAKER 0 194 27-Oct-2023, 10:50 AM
Last Post: PJKMBAKER
  Taranis & TD 100 [km] zomer 0 185 03-Sep-2023, 03:27 PM
Last Post: zomer
  Help RSSI callout Taranis QX7/OpenTX? swequad 1 254 13-Jul-2023, 03:05 PM
