How to test Esc's ?
I built an XHover Element with Xhover Esc's and motors. Im runnign a naze 32 rev6a. I have it together and everything is working fine but the signal wire are to long so i get the idea to pull them off cut and resoldier them. I have them all hooked back up but now 2 motor will not spin up and 2 will. Also the Naze will arm sometimes and them disarm immediately . Is there a way to test the esc and make sure they are messed up and not something else. I think i got them to hot you live and you learn but that also means i got 2 right lol.This is my second quad to build and second time to soldier my fisrt one worked fine but i didnt soldier this small stuff just the naze and it was fine . Also would it be on to run just a signal wire from them without the ground or power? Sorry I know this is a lot of questions ?
I found out the problem i was pluging them into 3456 channel. It was like 1 am when i tried last night. Im glad its something easy .Thats what i get for being a noob.
Nah, not noob.
It's called working past your functional brain time.
Happens all the time.
  New Product Flite Test EZ ID Remote ID Module SnowLeopardFPV 1 744 23-Sep-2023, 12:04 AM
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 233 01-Aug-2023, 11:22 AM
  Help ESC desync issues oyvinla 24 16,675 20-Feb-2023, 01:26 AM
Last Post: kibbycabbit
  Help Brushless motor or ESC broken? Not working properly after full throttle Niujaus 5 8,188 30-Apr-2019, 12:27 PM
Last Post: Drone0fPrey
  ESC mounting outside the box Krohsis 8 1,447 16-Mar-2019, 09:55 PM
Last Post: Krohsis
