18-Oct-2023, 05:15 PM
Hi All!
I need to setup the switch between hdmi and av outputs of camera SIYI A8 mini on RC transmitter. This camera supports both: digital and analog outputs. I have asked siyi if these outputs can work simultaneously and the answer is “Yes”. But there is no possibility to switch stream between digital and analog out of the box (on the fly). It’s something needs to be programmed/configured by clients. I saw there are FPV Video Switchers for analog-only output but I have found nothing for analog<->digital switch. Could you please suggest if there are any ways to implement that?
