19-Mar-2021, 04:35 PM
Hey guys,
I recently bought a my first ever FPV drone and already received some tips and trick setting it up
(It´s the iFlight Nazgul5 V2 by the way).
We had some terrible weather over here and today was the first day that I felt like taking it outside for a maiden flight.
But then I ran into an issue, after having everything setup I wanted to try the maiden flight, just like Joshua Bardwell explains it in his videos (slow roll, pitch & yaw and then trying to throttle up). But everytime I applied anything more than the slightest bit of throttle the drone would literally flip out.
So I googled what the issue might be and quickly ran into JB´s video about this topic:
I opened up betaflight and concluded the following things:
1. The motors are in the CORRECT order within betaflight
2. The motors spin the wrong direction
3. The FC board was not facing forward (that should be fixed)
4. Custom motor mix is obviously not possible since it´s a bind an flight.
So I quickly changed the orientation of the FC board and now the 3D-grafic shows everything correctly. (I added 90 degrees to the yaw axis within the "board and sensor allignment" section on the configuration page:
Altough I am wondering if the "reset Z axis, offset: -230 degrees" on the setup page is important (because I could easily put that to 0 if nessecary):
Now I am wondering on how to change the motor´s spinning direction, since it is the opposite of the configuration tab within betaflight.
I saw a video about how to do it within BL Heli and even installed it. But I haven´t had succes connecting my drone to it and am wondering if it is ever the correct software or way to go.
So basically what I want to know is how to reverse the motor spinning direction?
Thanks guys for helping me out once again.
