26-Apr-2017, 09:45 PM
Is there a secret magical way to remove these C-clips without breaking or losing them??
How to remove mini quad motor C-clips |
26-Apr-2017, 09:45 PM Is there a secret magical way to remove these C-clips without breaking or losing them?? use a C-clips pliers (that work reversed), and do it inside of a plastic bag so it doesn't go flying 26-Apr-2017, 09:49 PM Got a pair of c-clip pliers from home Depot had to grind down one of the tips to work on smaller clips. Purchased a bag of c-clips off the interwebs. Once you take it off its pretty much not a dependable clip anymore.. Side note. I gave up on motors with clips and cant convince myself to look at any of them with it. I have the emax 2205s. The screw alone makes life bett 27-Apr-2017, 03:02 AM Coming from mostly automotive c-clips, 9 times out of 10 we just replace them with new. 27-Apr-2017, 06:53 AM I normally toss my c-clips and install e-clips instead. They are much easier to remove/install. They are cheap on eBay and 2.5mm works for a 3mm shaft |
PWM circuit for a motor testing rig | Pathfinder075 | 10 | 127 | 11 hours ago Last Post: skywanderer | |
Recursion Labs - Sub 250g Motor and Propeller Testing | Recursion | 36 | 4,667 | 21-Mar-2024, 07:02 PM Last Post: skywanderer | |
Help ESC working but motor not spinning | Prashant1901 | 1 | 107 | 10-Mar-2024, 02:09 AM Last Post: Pathfinder075 | |
Motor or ESC ? | Flybyjim | 4 | 152 | 13-Feb-2024, 12:31 AM Last Post: Flybyjim | |
Tip & Trick Staggered motor wire joining, way neater. | ph2t | 2 | 482 | 28-Jan-2024, 05:31 PM Last Post: mstc |
