Threads: 76
Likes Received: 226 in 130 posts
Likes Given: 154
6 01-Apr-2020, 11:17 PM Hey friends --- So I've had a lot of fun flying my drone, but I've just messed up another VTX antenna as I can't seem to easily land this darn thing. Does anybody have some tips?
I've noticed that top mounted drones can kind of be plopped down at slow speeds because of the flat bottom, but not this oblivion, and I'm about tired of buying new antennas lol. I think I'm going to get a stubby.
Cheers
A Frustrated new pilot
Threads: 125
Likes Given: 99
388 02-Apr-2020, 12:02 AM (This post was last modified: 02-Apr-2020, 12:05 AM by voodoo614.) It just takes practice. And find someplace soft.
Try land a little further away from you. Where you will not hit anything. Don't think of trying to land. Just think about slowly descending. Ignore the ground. As soon as you hit the ground, disarm.
Threads: 108
Likes Given: 344
3 I disarm just before I hit the ground so props don't get caught up in grass. Also have foam landing pads stuck to the bottom of my arms to give me a bit of extra landing space.
Threads: 10
Likes Received: 10 in 8 posts
Likes Given: 7
1 I've heard about putting Air Mode on a switch and turning it off when landing can help. Air Mode can cause you to bounce against the ground until you disarm.
Threads: 19
Likes Received: 261 in 173 posts
Likes Given: 168
10 I find it better to have my disarm on the same side as my pitch and roll. This way I can make it level and leave it. I then adjust the throttle to get closer to the ground and disarm when I am 10 cm above ground.
Threads: 172
Likes Received: 2,286 in 1,833 posts
Likes Given: 4,737
100 you can switch to anglemode to land
Threads: 136
Likes Received: 1,790 in 1,052 posts
Likes Given: 3,302
50 With a bottom mount battery my best advice is to come in slow and low. Keep pitching back until you are looking up at an angle similar to your cam angle. As you feel your forward speed come to a stop, start lowering throttle slowly until you feel the ground and then kill it.
Basically just try to stop any forward momentum, come to a hover and descend.
Threads: 66
Likes Received: 352 in 254 posts
Likes Given: 490
12 I do a 180 spin to stop then disarm
