How to install replacement ESC`s
Hey
I got a problem with one of my ESC's, im trying to wire in a new ESC but the replacement one has four wires going to the flight controller but my Wizard x220 stock has three, im so confused can anyone help?
Most likely the 4th wire is the ground wire that connects to the flight controller. Is the "extra" wire a thinner black wire? If so, it is probably the ground. You can try not connecting it and see how it works. Some people don't connect the ground.
[-] The following 1 user Likes NoxNow's post:
  • sloscotty
I've never seen an ESC with four wires to the flight controller. How about posting some photos?
(23-Mar-2017, 09:45 AM)unseen Wrote: I've never seen an ESC with four wires to the flight controller. How about posting some photos?
I'm pretty sure he means to the flight stack and is including the +/- to the PDB in his wire count.  (That's how I understood it anyway - understandable for a new guy.) Big Grin
noimad, I'd be more concerned about adding a mismatched esc. I hope the one you are replacing it with is identical in other respects. It might be fine, but I'd be concerned.
(23-Mar-2017, 10:02 AM)sloscotty Wrote: I'm pretty sure he means to the flight stack and is including the +/- to the PDB in his wire count.  (That's how I understood it anyway - understandable for a new guy.) Big Grin
Yeah, that makes sense. They didn't bother connecting or even installing the signal grounds on the original ESCs. I always twist ground and signal wires together and connect both.
  • campagnium
(23-Mar-2017, 01:20 PM)unseen Wrote: Yeah, that makes sense. They didn't bother connecting or even installing the signal grounds on the original ESCs. I always twist ground and signal wires together and connect both.
*good to know.. Thumbs Up Big Grin
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 266 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 118 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 146 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 216 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 145 10-Mar-2024, 02:09 AM
