How to get Taranis subtrim beyond 100?
Is there a way to get taranis endpoint beyond 100 in the subtrim page?
Can't seem to get my throttle endpoints below 1020.
sounds like you need to first get your stick calibrated again.
If that's still a problem after, you might need to adjust the end point isntead: The raise or lower mid value (1500), then tweak the min and max values (1000 and 2000).
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 198 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  Taranis & TD 100 [km] zomer 0 193 03-Sep-2023, 03:27 PM
Last Post: zomer
  Help RSSI callout Taranis QX7/OpenTX? swequad 1 266 13-Jul-2023, 03:05 PM
  No tools/menu available (Taranis QX7) Felynx 6 3,813 19-May-2023, 06:41 AM
Last Post: BadRaven
  Help [SOLVED] help on setting up Taranis to change vtx band and channel with LUA script sim_tcr 10 1,186 24-Apr-2023, 08:20 AM
Last Post: sim_tcr
