After crash into snow, HifionRC F7 AIO has motor M2 stuttering and failing to spinup... then beeps twice. Demag, timing, flash ti BluJay make little difference.
All FET look ok. Tested caps for short. All diodes are 0.55V. The output 22ohm are all 22ohm. Seems like cant detect the emf to spin right.
I kinda know what should be:
Each 10k resistor connect to each motor pad.
The 1.5K connected to gnd
The 4K connected to common.. where they all meet, and go into Fortior input sense.
But on bad M2, all "10K" measure around 5.5K and all beep continuity to all motor pads.
I tried replacing the
0201 10k.. Same
0201 10k.. Same
