How to do flips and rolls?
Hi
When you do flips or rolls, are you cut throttle to zero when quad is upside down...?
Or it depends slow or fast trick you do?
My Instagram - and -  Facebook
For a basic roll or flip, cut throttle and do the move, then back on throttle. However, you will lose altitude with that method unless that's what you want.
If you want stay the same altitude, blip the throttle up, then cut to start floating, then do the move, then back on.
Unless you are running betaflight's Airmode or have a switch to keep your throttle running when armed, I never go to 0% throttle because your quad will become unstable and bad things may happen. I'd drop down to maybe 10% when doing rolls.
Try it at different throttle levels and you'll see how the quad behaves. It's very different throughout the powerband.
this might help you Smile
http://intofpv.com/t-how-to-do-a-flip-ro...quadcopter
(28-Jan-2016, 06:02 PM)Arknabbit Wrote: For a basic roll or flip, cut throttle and do the move, then back on throttle.  However, you will lose altitude with that method unless that's what you want.
Thnx, but if you "blip the throttle up" before flip you probably climb altitude yes?
But in some, video guys do flips when flying through gates or windows how?
floating - it is 50% throttle or when quad hover?
  Quad suddenly rolls to the right and then falls off the sky doronba 15 2,735 18-Aug-2020, 05:44 PM
Last Post: unseen
  Runcam Split 2 video cut out agressive flips gmk 5 2,298 13-Nov-2017, 03:54 PM
Last Post: raspberrypi33
  Quad flips after replacing ESC hanism 3 953 15-Jul-2017, 12:11 PM
Last Post: fftunes
  Quad flips in midair, help! less than 1 minute after takeoff ... adians 3 1,065 06-Dec-2016, 07:16 PM
Last Post: varkokonyi
