Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 3
0 Ok so I am posting here instead of the FB page, Anyone have any ideas in regards to fixing yaw issues on my TX? It doesn't ever return to 0. It does this on 3 different models the same way and same issues in OpenPilot, Taulabs, and Cleanflight. I finally narrowed it down to my TX. I am using Turnigy 9x with openTX. As trimming on TX is bad and has no effect on the yaw drift. Would changing the gimbals to the Taranis ones do the trick?
Threads: 672
Likes Given: 2,027
139 On the clean flight configurator, what value do you get when yaw is centred? You can set up offset in the input or channel mixer I think if it's more than trim can handle
Threads: 3
Likes Given: 3
0 I re-calibrated my tx, and will see if that did the trick. The position read out in open tx yaw was always landing on -10 or 10. Stopped on 0 like it should after calibrating. Is it normal to have to calibrate all the time?
Threads: 672
Likes Given: 2,027
139 Not really.. Sounds like it might be a mechanical issue what you have
Threads: 3
Likes Given: 3
0 That's why I was thinking of replacing the gimbals. Thanks!
