We started a spare parts donation program, check it out :) http://intofpv.com/forum-spare-parts-exchange
Our IntoFPV LiPo Straps are back in stock! Purchase Here
How do I check if a TX is compatible with PPM?
My colleague and me are we building this FPV Micro Quad: https://oscarliang.com/fpv-micro-quad-beef-board/
We have a TX from other Quad (a toy) but we tried bind them with unsuccessful result. I guess our TX doesn't support PPM, but I'm not completely sure. The TX doesn't have any sticker or code for looking for related information.
If the problem is compatibility with PPM, maybe could you recommend us a TX cheaper than Taranis compatible with PPM for beginners?
Big Grin
Hi there!
PPM is a protocol used between the receiver and the flight controller so it has nothing to do with the communication between your radio and your receiver. For those 2 to work together they need to support a common protocol like DSM2 or DSMX just for instance.
There's a post on Oscar's blog explaining all this in detail, you may want to start there: https://oscarliang.com/pwm-ppm-sbus-dsm2...ifference/
Chances are that your toy radio and the receiver you're using aren't compatible. What are the brands and models of your parts?
There are several cheap alternatives to the Taranis, for example the FlySky radios/receivers are quite decent and reasonably cheap.
Than RX looks like a micro FRSKY
Find me on Youtube and Instagram. I currently fly: NOX5, NOX5RAirblade Assault 130 and drive a scrap RC car
Thank you for your reply.
The receiver is Micro FrX http://fisselrc.com/microfrx/
But I'm not sure what type TX is. I'll try open it and look for something useful for identify the protocol in the TX.
How can I know if "FlySky FS-i6-M2 2.4GHz 6-Channel Transmitter" is compatible with my receiver? https://www.amazon.com/gp/product/B00PF1...PDKIKX0DER
(11-Oct-2016, 11:59 AM)Fran Wrote: How can I know if "FlySky FS-i6-M2 2.4GHz 6-Channel Transmitter" is compatible with my receiver? https://www.amazon.com/gp/product/B00PF1...PDKIKX0DER
i6 will only be compatible with flysky receivers, you have a frsky one which uses different protocol.
I opened the TX and I didn't see anything related to DSMX, DSM2, DJT, DFT, DHT, XJT...
I think RX and TX are not compatibles so I should buy a new TX. Probably this works, although I find it a bit expensive (my idea was something about 80$ max.):  http://www.hobbyking.com/hobbyking/store...ch=taranis
There is a cheaper radio that can accept a frsky module (bought separately): http://www.hobbyking.com/hobbyking/store...dule_.html
But I don't know much about it, maybe we have someone here that uses a 9xr pro?
if you're on a 80$ budget, I would probably go for the flysky fs-i6 (45$) (or the new fs-i6x for 50$, maybe not released yet). there is a receiver included with both of them which supports ibus/ppm/pwm.
http://www.banggood.com/FlySky-FS-i6-2_4...mds=search
Hi all!
I have just received the flysky fs-i6 but I don't get this work. I'm following the instruction from: http://fisselrc.com/microfrx/#binding
  1. Remove all power.
  2. Turn your TX on in binding mode. (Bind Key on fs-i6)
  3. Temporarily short(connect) the "BIND" pads (I use tweezers)
  4. Once bound you should get a steady slow blinking light.  <-- This doesn't happen
  5. Remove all power.
  6. Make sure Bind pins are no longer shorted(connected).
  7. Reset TX or Turn off binding mode.
  8. Turn on your TX and RX.
  9. You should now be bound
Microfrx has a red light that stays on. I'm not sure about the meaning of this light because in the FAQ only says 3.3V (Does it means voltage is OK?)
In addition, I flashed the controller with last firmware version of Naze32. In a validation step I got "STM32 communication failed, wrong response, expected: 121 (0x79) received: 31 (0x1f)" but I can connect to clean flight. I found something related to this: Fixing STM32 communication failed but neither I found the "BOOT pins" for this controller so I couldn't apply this solution.
Any idea or advise?
Attached Files Thumbnail(s)
(06-Dec-2016, 01:09 PM)Fran Wrote: Hi all!
  4. Apply power to the RX
  5. Once bound you should get a steady slow blinking light.  <-- This doesn't happen
  6. Remove all power.
  7. Make sure Bind pins are no longer shorted(connected).
  8. Reset TX or Turn off binding mode.
  9. Turn on your TX and RX.
  10. You should now be bound
Any idea or advise?
You must power up the RX, i have added in your steps.
I powered up the RX but with the same result. This is the video with my try:
Maybe I performed a mistake or something is missing.
Might be the tweezers do not transmit enough power, they are completely metallic and I take them with the fingers (just to say something). The voltmeter between BIND pins displays 2.9V which I guess is a normal value.
  Help Turnigy 9X and PPM Compatible receiver bsb395 5 1,273 10-Jul-2017, 09:33 AM
Last Post: Grantham Kid
  FS-I6S compatible with X4R? solcalderon 5 1,019 06-Feb-2017, 01:00 AM
Last Post: Grisha0
  Discussion TX that are compatible with D4R-II JoshSky 1 302 01-Oct-2016, 07:18 PM
Last Post: thomasFPV
