Threads: 1
Likes Received: 0 in 0 posts
0 10-Jun-2021, 05:58 PM (This post was last modified: 10-Jun-2021, 05:59 PM by Krishna.) Hi i am krishna
I want to make a smoke stopper but in india the smoke stopper bulb is not available so i find a bike indiactor's filament bulb which matches the watt and voltage to the 3157 autmotive bulb so can i use it???
Threads: 592
Likes Received: 9,022 in 6,677 posts
Likes Given: 1,428
793 Yes, you can use that alternative bulb no problem.
Threads: 1
0 Can I use a bulb which gives output current of 2.7 amps or it will fry my parts?
Threads: 125
Likes Given: 99
388 11-Jun-2021, 05:15 PM (This post was last modified: 11-Jun-2021, 05:17 PM by voodoo614.) Most likely you will be OK for larger quad. But on smaller quad, you probably want a bulb in the 1-2A. The beauty of a bulb, your will see the short slowly light up the bulb. Gives you a split second to disconnect. Take note, the bulb will light up dimly than settle down in most situation. It is when it goes super bright that you have a short.
