Posts: 9 Threads: 4 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Jun 2016 Reputation: 0 10-Jun-2016, 07:32 AM (This post was last modified: 10-Jun-2016, 07:33 AM by ganked.) Hi Everyone, =Background= I have re-tuned on Betaflight 2.8.0 recently (not that I think that has anything to do with it) and switched to DAL 5045x3 Tri-blade props. I am running: 210 frame Sunnysky 2204x 2300kv Littlebee 20A Naze32 Rev6 Turnigy Graphene 1300mAh 4S 65C Lipo =The Problem= I was flying lower PID gains on the Tri blades and all seemed pretty cool. Then I spent the last few days tuning. After tuning it up, it's flying amazing and very locked in, however the Sunnysky motors are coming down very hot. I think it's just that they are rated 2S-3S and i'm obviously running 4S. Flight time is very short as well (2-3.5 mins). =Questions= 1) Could my P gains which I reckon are high (still no real P oscillations though) be causing the motors to heat up? Could I tune the heat down by reducing P? 2) Do I have to fall back to regular dual blade props? 3) Does anyone else run tri-blades with 4S on Sunnyskys without issues? 4) Do I need better motors? Thanks in advance. I can post my Betaflight dump later on tonight. Thanks in advance. Sean • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 Common problem with motors overheating is too high D. From what I've read 2.8.0 needs a lot lower D (someone suggested even lower than 10). Maybe that's the cause? • Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 I have pretty much the same setup, and my motors are cool when landing. Flight time is about 3-4 min. Running 2.8.0 and blheli 14.6 • Posts: 9 Threads: 4 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Jun 2016 Reputation: 0 Thanks for the insights. When you say too high D. I was raising P until I just started to get osc, then I started adding D to see if I could leave P high and soften out those big gyro moves with D. Maybe this will help more. Here is my CLI dump and PIDs. # dump all # version # BetaFlight/NAZE 2.8.0 Jun 5 2016 / 00:30:38 (d9e28cd) # dump master # mixer mixer QUADX mmix reset smix reset # feature feature -RX_PPM feature -VBAT feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -FAILSAFE feature -SONAR feature -TELEMETRY feature -CURRENT_METER feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -ONESHOT125 feature -BLACKBOX feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -SUPEREXPO_RATES feature VBAT feature RX_SERIAL feature MOTOR_STOP feature SOFTSERIAL feature FAILSAFE feature TELEMETRY feature ONESHOT125 feature SUPEREXPO_RATES # beeper beeper -GYRO_CALIBRATED beeper -RX_LOST beeper -RX_LOST_LANDING beeper DISARMING beeper ARMING beeper -ARMING_GPS_FIX beeper -BAT_CRIT_LOW beeper -BAT_LOW beeper -GPS_STATUS beeper RX_SET beeper -ACC_CALIBRATION beeper -ACC_CALIBRATION_FAIL beeper -READY_BEEP beeper -MULTI_BEEPS beeper -DISARM_REPEAT beeper -ARMED beeper -SYSTEM_INIT beeper -ON_USB # map map AETR1234 # serial serial 0 1 115200 57600 0 115200 serial 1 64 115200 57600 0 115200 serial 30 32 115200 57600 0 115200 serial 31 0 115200 57600 0 115200 # led led 0 15,15:ES:IA:0 led 1 15,8:E:WF:0 led 2 15,7:E:WF:0 led 3 15,0:NE:IA:0 led 4 8,0:N:F:0 led 5 7,0:N:F:0 led 6 0,0:NW:IA:0 led 7 0,7:W:WF:0 led 8 0,8:W:WF:0 led 9 0,15:SW:IA:0 led 10 7,15:S:WF:0 led 11 8,15:S:WF:0 led 12 7,7:U:WF:0 led 13 8,7:U:WF:0 led 14 7,8:WF:0 led 15 8,8:WF:0 led 16 8,9::R:3 led 17 9,10::R:3 led 18 10,11::R:3 led 19 10,12::R:3 led 20 9,13::R:3 led 21 8,14::R:3 led 22 7,14::R:3 led 23 6,13::R:3 led 24 5,12::R:3 led 25 5,11::R:3 led 26 6,10::R:3 led 27 7,9::R:3 led 28 0,0:::0 led 29 0,0:::0 led 30 0,0:::0 led 31 0,0:::0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 90,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # aux aux 0 0 1 1700 2100 aux 1 27 0 1700 2100 aux 2 12 3 1700 2100 aux 3 0 0 900 900 aux 4 0 0 900 900 aux 5 0 0 900 900 aux 6 0 0 900 900 aux 7 0 0 900 900 aux 8 0 0 900 900 aux 9 0 0 900 900 aux 10 0 0 900 900 aux 11 0 0 900 900 aux 12 0 0 900 900 aux 13 0 0 900 900 aux 14 0 0 900 900 aux 15 0 0 900 900 aux 16 0 0 900 900 aux 17 0 0 900 900 aux 18 0 0 900 900 aux 19 0 0 900 900 # adjrange adjrange 0 0 0 900 900 0 0 adjrange 1 0 0 900 900 0 0 adjrange 2 0 0 900 900 0 0 adjrange 3 0 0 900 900 0 0 adjrange 4 0 0 900 900 0 0 adjrange 5 0 0 900 900 0 0 adjrange 6 0 0 900 900 0 0 adjrange 7 0 0 900 900 0 0 adjrange 8 0 0 900 900 0 0 adjrange 9 0 0 900 900 0 0 adjrange 10 0 0 900 900 0 0 adjrange 11 0 0 900 900 0 0 adjrange 12 0 0 900 900 0 0 adjrange 13 0 0 900 900 0 0 adjrange 14 0 0 900 900 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # servo servo 0 1000 2000 1500 90 90 100 -1 servo 1 1000 2000 1500 90 90 100 -1 servo 2 1000 2000 1500 90 90 100 -1 servo 3 1000 2000 1500 90 90 100 -1 servo 4 1000 2000 1500 90 90 100 -1 servo 5 1000 2000 1500 90 90 100 -1 servo 6 1000 2000 1500 90 90 100 -1 servo 7 1000 2000 1500 90 90 100 -1 set mid_rc = 1500 set min_check = 1100 set max_check = 1900 set rssi_channel = 7 set rssi_scale = 30 set rssi_ppm_invert = OFF set input_filtering_mode = OFF set rc_smoothing = OFF set roll_yaw_cam_mix_degrees = 0 set max_aux_channels = 6 set debug_mode = NONE set min_throttle = 1025 set max_throttle = 2000 set min_command = 1000 set anti_desync_power_step = 10000 set servo_center_pulse = 1500 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set unsynced_fast_pwm = OFF set fast_pwm_protocol = ONESHOT125 set motor_pwm_rate = 400 set servo_pwm_rate = 50 set disarm_kill_switch = ON set gyro_cal_on_first_arm = OFF set auto_disarm_delay = 5 set small_angle = 25 set fixedwing_althold_dir = 1 set reboot_character = 82 set serialrx_provider = SBUS set sbus_inversion = ON set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = 1 set telemetry_switch = OFF set telemetry_inversion = ON set frsky_default_lattitude = 0.000 set frsky_default_longitude = 0.000 set frsky_coordinates_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set frsky_vfas_cell_voltage = OFF set hott_alarm_sound_interval = 5 set battery_capacity = 0 set vbat_scale = 110 set vbat_max_cell_voltage = 43 set vbat_min_cell_voltage = 33 set vbat_warning_cell_voltage = 35 set vbat_hysteresis = 1 set vbat_pid_compensation = OFF set current_meter_scale = 400 set current_meter_offset = 0 set multiwii_current_meter_output = OFF set current_meter_type = ADC set align_gyro = DEFAULT set align_acc = DEFAULT set align_mag = DEFAULT set align_board_roll = 0 set align_board_pitch = 0 set align_board_yaw = 0 set max_angle_inclination = 700 set gyro_lpf = OFF set gyro_sync_denom = 4 set gyro_lowpass = 100 set moron_threshold = 32 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set alt_hold_deadband = 40 set alt_hold_fast_change = ON set deadband = 0 set yaw_deadband = 0 set throttle_correction_value = 0 set throttle_correction_angle = 800 set yaw_control_direction = 1 set yaw_motor_direction = 1 set tri_unarmed_servo = ON set servo_lowpass_freq = 400 set servo_lowpass_enable = OFF set airmode_activate_throttle = 1350 set failsafe_delay = 10 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_kill_switch = OFF set failsafe_throttle_low_delay = 100 set failsafe_procedure = ON set rx_min_usec = 885 set rx_max_usec = 2115 set gimbal_mode = NORMAL set acc_hardware = NONE set acc_lpf_hz = 10.000 set accxy_deadband = 40 set accz_deadband = 40 set acc_unarmedcal = ON set acc_trim_pitch = 0 set acc_trim_roll = 0 set baro_tab_size = 21 set baro_noise_lpf = 0.600 set baro_cf_vel = 0.985 set baro_cf_alt = 0.965 set baro_hardware = NONE set mag_hardware = NONE set mag_declination = 0 set pid_process_denom = 1 set blackbox_rate_num = 0 set blackbox_rate_denom = 0 set blackbox_device = SERIAL set magzero_x = 0 set magzero_y = 0 set magzero_z = 0 set ledstrip_visual_beeper = OFF # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # profile profile 0 ############################# PROFILE VALUES #################################### set yaw_p_limit = 500 set dterm_lowpass = 110 set dynamic_pid = ON set iterm_ignore_threshold = 200 set yaw_iterm_ignore_threshold = 45 set yaw_lowpass = 80 set pid_controller = MWREWRITE set p_pitch = 89 set i_pitch = 59 set d_pitch = 31 set p_roll = 72 set i_roll = 52 set d_roll = 28 set p_yaw = 117 set i_yaw = 54 set d_yaw = 10 set p_alt = 50 set i_alt = 0 set d_alt = 0 set p_level = 50 set i_level = 50 set d_level = 100 set p_vel = 55 set i_vel = 55 set d_vel = 75 rateprofile 2 # rateprofile rateprofile 0 set rc_rate = 140 set rc_rate_yaw = 160 set rc_expo = 5 set rc_yaw_expo = 0 set thr_mid = 50 set thr_expo = 60 set roll_rate = 60 set pitch_rate = 60 set yaw_rate = 30 set tpa_rate = 20 set tpa_breakpoint = 1650 # rateprofile rateprofile 1 set rc_rate = 100 set rc_rate_yaw = 100 set rc_expo = 10 set rc_yaw_expo = 10 set thr_mid = 50 set thr_expo = 0 set roll_rate = 70 set pitch_rate = 70 set yaw_rate = 70 set tpa_rate = 20 set tpa_breakpoint = 1650 # rateprofile rateprofile 2 set rc_rate = 100 set rc_rate_yaw = 100 set rc_expo = 10 set rc_yaw_expo = 10 set thr_mid = 50 set thr_expo = 0 set roll_rate = 70 set pitch_rate = 70 set yaw_rate = 70 set tpa_rate = 20 set tpa_breakpoint = 1650 # profile profile 1 ############################# PROFILE VALUES #################################### set yaw_p_limit = 500 set dterm_lowpass = 110 set dynamic_pid = ON set iterm_ignore_threshold = 200 set yaw_iterm_ignore_threshold = 45 set yaw_lowpass = 80 set pid_controller = MWREWRITE set p_pitch = 45 set i_pitch = 40 set d_pitch = 15 set p_roll = 45 set i_roll = 40 set d_roll = 15 set p_yaw = 90 set i_yaw = 45 set d_yaw = 20 set p_alt = 50 set i_alt = 0 set d_alt = 0 set p_level = 50 set i_level = 50 set d_level = 100 set p_vel = 55 set i_vel = 55 set d_vel = 75 rateprofile 2 # rateprofile rateprofile 0 set rc_rate = 100 set rc_rate_yaw = 100 set rc_expo = 70 set rc_yaw_expo = 20 set thr_mid = 50 set thr_expo = 0 set roll_rate = 50 set pitch_rate = 50 set yaw_rate = 50 set tpa_rate = 20 set tpa_breakpoint = 1650 # rateprofile rateprofile 1 set rc_rate = 100 set rc_rate_yaw = 100 set rc_expo = 10 set rc_yaw_expo = 10 set thr_mid = 50 set thr_expo = 0 set roll_rate = 70 set pitch_rate = 70 set yaw_rate = 70 set tpa_rate = 20 set tpa_breakpoint = 1650 # rateprofile rateprofile 2 set rc_rate = 100 set rc_rate_yaw = 100 set rc_expo = 10 set rc_yaw_expo = 10 set thr_mid = 50 set thr_expo = 0 set roll_rate = 70 set pitch_rate = 70 set yaw_rate = 70 set tpa_rate = 20 set tpa_breakpoint = 1650 # restore original profile / rateprofile selection profile 0 rateprofile 2 # save configuration save # • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 In general Your PID's look high to me. Read short note from betaflight wiki: https://github.com/betaflight/betaflight...hat-normal- Don't know Your method of tuning, but it may be a good idea to read trough this: https://github.com/betaflight/betaflight...ning-Guide • Posts: 9 Threads: 4 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Jun 2016 Reputation: 0 Hi Konrad, Thanks for talking through this with me. I have previously read those many times over (not saying I know it all though). I started this re-tune from stock 2.8.0 PIDs and then dropped D and P and started from there. Get I a little higher, then started increasing P on roll. I personally reckon maybe my P was a little high now, as I have HD footage since that last tune and I am getting the slightest P gain osc at full throttle and due to TPA being 20%, would likely point to my P gains being slightly too high. I'll back them down a tad and give it another fly tomorrow. But in theory, do you think the Sunnysky motors should be fine on those tri-blade 5045 props? • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 10-Jun-2016, 01:09 PM (This post was last modified: 10-Jun-2016, 01:15 PM by KonradS.) I used 5045x3 BN DALs on cobra 2204 2300kv which is also 3s rated and I had to drop D a bit on betaflight 2.6.1 because they came down very hot. D was closer to 17 before the drop. People report having to drop D even more on 2.8.0. EDIT: I had some horrible wobble and dropped I and D by a lot - like 10/5, having P close to 60. The wobble didn't disappear (bashed up DAL props... DOH!) so I changed to a lot lighter prop (KK 5040 which are smooth enough) and the copter flew quite well considering too low gains. Obviously I need to retune again, but it looks like low I and, especially D, are the way to go now. It was visible/aubible even during flights with wobbly props... • Posts: 9 Threads: 4 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Jun 2016 Reputation: 0 So 2.8.0 basically forces D down. Then how do I deal with the prop wash? My P gains don't "need" to be as high as they are. So I'll start to decrease them and see if it helps me bring down D too. Hopefully it helps me keep the tri-blades on. • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 (10-Jun-2016, 01:18 PM)ganked Wrote: So 2.8.0 basically forces D down. Then how do I deal with the prop wash? My P gains don't "need" to be as high as they are. So I'll start to decrease them and see if it helps me bring down D too. Hopefully it helps me keep the tri-blades on. That forcing may be connected to the fact that most people are flying 2khz+ looptimes. Imagine how oscillations impact Your motors when it's even faster? Some targets achieve 32khz on raceflights - You don't even hear that Your quad is oscillating at those frequencies • Posts: 9 Threads: 4 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Jun 2016 Reputation: 0 Is it a good idea to reduce loop time to 1k to tune? Is tuning in 2k bad practice? Will I be missing the oscillations that would generally be more audible on 1k? Thanks in advance. • Posts: 1,070 Threads: 70 Likes Received: 742 in 378 posts Likes Given: 577 Joined: Jan 2016 Reputation: 44 If You want to fly on 2khz, tune on it. On next retune I'll start on defalut P and low I and D. But currently I'm just learning how to do it properly Last step of tuning will be trough blackbox anyway. • |
