HK Blue 12A ESC - Revert to original firmware?
Does anyone know if it's possible to revert a HK BLue 12A ESC to the stock firmware?  I have some which I originally flashed with BLHeli for multi-rotor use.  Now I want to use one in a flying wing and it seems like it would make more sense to revert to the original firmware so I can get the original voltage cutoff settings etc back.
I couldn't seem to find the original firmware anywhere so that I can re-flash back to that.  Does anyone know if it's available somewhere?
I don't think that's possible unless you have the stock firmware file... which seems to be to be an impossibility. once you flash a different firmware the original is erased.
(17-Oct-2017, 09:08 PM)Oscar Wrote: I don't think that's possible unless you have the stock firmware file... which seems to be to be an impossibility. once you flash a different firmware the original is erased.
I actually have an un-modified ESC exactly the same I wonder if it's possible to dump a copy from that.  If so I'm surprised someone hasn't done it already and uploaded a copy somewhere online.
Unfortunately, most ESCs have the internal flash protection bits set so that you can't read out the original firmware.
(18-Oct-2017, 07:09 AM)unseen Wrote: Unfortunately, most ESCs have the internal flash protection bits set so that you can't read out the original firmware.
You're right.  I tried reading off my virgin one and no luck.  Have just used that one instead.  Shame there don't seem to be any custom fixed wing focused firmwares.
I buy HobbyWing FlyFun ESCs for my fixed wing stuff. They don't cost lots of money and neither does the programming card.
It's not about the cost, I just don't like the idea of the natural resources that went in to them being wasted.
  Motor fail, how to tell if it is the ESC or FC? husafreak 3 126 04-Mar-2024, 10:20 PM
  20x20 esc on 6s 5”? Rob Axel 6 237 01-Mar-2024, 07:18 AM
Last Post: Recursion
  Motor ESC connections. Griffin Ucos 4 217 03-Dec-2023, 02:02 PM
Last Post: Griffin Ucos
  Blheli32 / esc telemetry to matekf405te klick8484 13 599 28-Nov-2023, 07:11 AM
Last Post: voodoo614
  bent pin on FC to ESC connector aerokam 0 245 30-Jun-2023, 06:14 PM
Last Post: aerokam
