13-May-2017, 05:02 AM
Hey guys, I have had a niggle at my brain since Oscar's review of the X1 whoop with 7mm motors.
So as I understand it, motors wound to give a lower KV produce more torque, the more torque driving the prop the less it slows down from increased resistance yeah? i.e when descending quickly the air is trying to force the props to turn in the opposite direction, the more torque the motors provide, the less the props are effected by this and the quicker you should be able to halt the descent?
Now I thought that props would have to be designed for higher torque motors and given a higher AOA to make use of the additional torque and lack of RPM, but as Oscar said that the props on the X1 look exactly the same as the E010/H36 etc. I am a bit confused that the upgraded motors for the tinywhoop are all a higher kv?
So I was thinking about brushless micro's and thought that if a frame supports 110x motors surely one would be better off getting 1106 motors rather than 1103, but then I saw that there are Realacc 6000kv 1106 and Racerstar 3800kv 1106... That is quite a difference in RPM, would 3800kv be fast enough for a 1935 prop?
Thanks for any help.
