Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 31-Dec-2019, 03:55 AM (This post was last modified: 31-Dec-2019, 09:29 AM by Tooom.) Can someone help me on this one - I'm at the point almost out of ideas? I am new to FrSky as a previous Spektrum flyer. And I decided to try and run the R9m (full size) on a Xlite Pro with a module adaptor ... I cannot seem to get it to bind after lots of trying! I have Open Tx 2.3.3, I flashed the receiver (r9 mini) with the latest FLEX firmware ( 190117 2019-09-10), Flashed the R9M external module with the R9M 2019 corresponding FLEX firmware (190117 2019-02-13) Flashed the radio with opentx-xlites-flexr9m-lua-noheli-en (the selection on the Open Tx companion app says Xlite s or Xlite pro) Questions) 1) For the R9 mini firmware it says Fport and Sport should be switchable in the radio. I am unable to change this on the Xlite pro ..? 2) Why would my SD card not recognise? The SD card is the latest version (25) and the type requested by the radio? 3) I haven't flashed the internal RF firmware for the Xlite Pro (but I have this disabled so surely it wouldnt matter? 4) I am trying to bind primarily with R9M ACCESS but it will not work - is this the correct selection? 5) I also tried binding with R9M FCC (915MHz). But the external module will not register, and again it will not bind. Further info that may be relevant, I have red light on the nack of the r9m and red and green lights on the r9 mini when attempting to bind -> see video I am trying to run this with Access, Fport and Flex ideally Please send help@@! Couple more points I have noticed on the Xlite Pro webpage ( https://www.frsky-rc.com/taranis-x-lite-pro/) the firmware is requiring SD Version : 2.3v0019, Whereas the firmware being installed by my Open Tx companion app is installing a firmware version requiring SD card contents 2.3v0025 .......... could the companion app be installing the incorrect firmware even when the correct radio type is selected?? I have setup my Kakute f7 primarily following these links https://oscarliang.com/setup-r9m-r9-mini-betaflight/ & https://oscarliang.com/setup-frsky-fport/ and I have this CLI code: set serialrx_halfduplex = ON set serialrx_inverted = OFF save • Posts: 12,098 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 31-Dec-2019, 09:39 AM (This post was last modified: 31-Dec-2019, 09:39 AM by voodoo614.) 1) For the R9 mini firmware it says Fport and Sport should be switchable in the radio. I am unable to change this on the Xlite pro ..? You have to bind using ACCESS. Then you should have the ability to switch F. Port/ s. Port in Radio. 2) Why would my SD card not recognise? The SD card is the latest version (25) and the type requested by the radio? What format is SD card formatted. 3) I haven't flashed the internal RF firmware for the Xlite Pro (but I have this disabled so surely it wouldnt matter? Should not effect the rest of the world. 4) I am trying to bind primarily with R9M ACCESS but it will not work - is this the correct selection? It looks like you are bound. You have a solid green light. 5) I also tried binding with R9M FCC (915MHz). But the external module will not register, and again it will not bind If you are not binding, it is likely a firmware issue with FC. I would reflash radio and firmware again. • Posts: 21,358 Threads: 592 Likes Received: 9,019 in 6,675 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 793 31-Dec-2019, 02:15 PM (This post was last modified: 31-Dec-2019, 02:15 PM by SnowLeopardFPV.) I can see in your video that you are getting a solid red and green light on the R9 mini which means it it still in "waiting to bind" or "register" mode so it has failed to complete the binding process as you said. Is the receiver a regular R9 Mini or is it the newer R9 Mini-OTA version? • Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 31-Dec-2019, 03:00 PM (This post was last modified: 31-Dec-2019, 03:11 PM by Tooom.) Thansk for taking the time to reply guys. It is not the OTA version it is the older R9mm (not mini - I have both sorry). I believe the SD card is formatted correctly as I can access it in the radio and flash from it, it's just it brings up the SD card expected version error on startup. I think it isn't bound as it should be just a solid green light only I thought? Is this correct as the manual isn't great on the binding. What the different flashing on the reciever means for example. I have reflashed my firmware to the latest ACCESS. I think before I had flashed the flex firmware when I should have been using the Access firmware. So now I can get through the module registration successfully and it says its ok. However when I try bind I now get slow flashing of both the green and red LEDs, so I do not think a successful bind still. No control on betaflight either see updated video below: Could I ask if anyone knows if my inversion betaflight CLI code / wiring is correct for F port, Kakute F7. I tried to just follow Oscars posts on it? Again any help and sanity check is very appreciated - been grounded for 2 months waiting for postage and messing around with this. • Posts: 21,358 Threads: 592 Likes Received: 9,019 in 6,675 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 793 First off, regarding the SD Card warning, it means you have the wrong version of the SD card contents. It should say the expected version on that warning screen (which should be 2.3v0025 for OpenTX 2.3.3) which can be found HERE. Follow Oscar's guide at the link below on how to update the SD Card contents... https://oscarliang.com/flash-opentx-firmware-taranis Below is the registration and binding process for ACCESS receivers so give this a go and see if it works... Quote:Registration & Automatic binding (Smart Match) With the FrSky ACCESS protocol, the transmitter/transmitter module can bind receiver without using the "F/S" button. Follow the step below to finish the Registration & binding procedure: - Put the transmitter/transmitter module into [Reg] status. For Taranis X-Lite Pro as an example, turn on the transmitter, go to the MENU-MODEL SETUP-PAGE 2, choose External RF-Mode R9MLP ACCESS, then select [Reg].
- Connect the battery to the receiver while holding the F/S button on the receiver. The RED LED and GREEN LED on the receiver will be on, indicating into the [Reg] status. Select [ENTER] on the transmitter, The RED LED and GREEN LED on the receiver will flash, and the transmitter displays [Registration ok].
- Turn off the receiver.
- Move the cursor to select the receiver 1 [Bind].
- Connect the battery to the receiver, the GREEN LED on the receiver will be on, indicating into the [Bind] status. Select the RX, and the transmitter displays [Bind successful].
- The transmitter exit [Bind], GREEN LED will flash, RED LED will be off, indicating working normally.
• Posts: 21,358 Threads: 592 Likes Received: 9,019 in 6,675 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 793 31-Dec-2019, 04:02 PM (This post was last modified: 31-Dec-2019, 04:07 PM by SnowLeopardFPV. Edit Reason: Typo corrections. ) I just realised I forgot to include the LED statuses for ACCESS on the R9MM / R9 Mini. See below. According to the status you are seeing, registration has been successful, but you are not yet bound which is why I put the steps in my previous post. So try that procedure and see if it rectifies things. Quote:Red LED Green LED Status ======= ========= ====== On On Register Flash Flash Register successfully Off On Bind Off Flash Work Normally Flash Off Failsafe Please provide some photos of the wiring and solder joints between your R9MM and the Kakute F7, and please also post a CLI dump of your Betaflight settings so we can take a look over them. • Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 13-Jan-2020, 10:36 AM (This post was last modified: 14-Jan-2020, 04:30 AM by Tooom.) Thankyou @SnowleopardFPV apologies for not getting back sooner I work away from home. I have reflashed receiver and Tx with R9mm firmware for Access. (I am trying with my r9mm instead of r9 mini now) and no longer on the flex firmware. I have tried your tips. I can now get a successful registration which is great - unfortunately when I then go to the next step on your list and try to bind I cannot get the bind. The green light stays solid and I do not get any confirmation on the Tx - it just keeps trying to bind. I will provide images of my board and the diff CLI dump you mentioned. Am I right with this CLI code since I have an F7 board and a R9mm - I am wired as in my image above ? set serialrx_halfduplex = ON set serialrx_inverted = OFF save (The only thing I did different from your binding instructions was to use R9M ACCESS instead on the R9MLP Access. I have the latest SD card 2.3v0025 which is the strange part still get the SD card warning. • Posts: 21,358 Threads: 592 Likes Received: 9,019 in 6,675 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 793 I just need to check because I made an assumption from your first post that your R9M module is the 2019 version? Can you please clarify that "R9M 2019" is actually printed on the back of the module and that "ACCST" doesn't appear anywhere on it. What I'm trying to get at here is that you haven't just flashed ACCESS firmware to an ACCST R9M module, because that won't work. Assuming that you are going to be using the FPORT protocol with the S.Port pad on the R9MM (pin 2) wired to the T4 pad on the Kakute F7, you need to switch Serial RX on for UART4 (and off for all other UARTs), then you need to run the following commands in the CLI:- Code: feature -RX_PPM feature -RX_PARALLEL_PWM feature RX_SERIAL feature TELEMETRY set serialrx_provider = FPORT set serialrx_halfduplex = ON set serialrx_inverted = ON save
Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 14-Jan-2020, 01:19 AM (This post was last modified: 14-Jan-2020, 01:26 AM by Tooom.) Code: # diff # version # Betaflight / KAKUTEF7 (KTF7) 4.0.3 Jun 1 2019 / 11:32:26 (094cfc956) MSP API: 1.41 # start the command batch batch start board_name manufacturer_id # name # resources resource MOTOR 1 E09 resource MOTOR 2 E11 resource MOTOR 3 B00 resource MOTOR 4 B01 # timer # dma # mixer # servo # servo mix # feature feature -AIRMODE feature GPS # beeper # beacon # map map TAER1234 # serial serial 0 8192 115200 57600 0 115200 serial 1 2 115200 57600 0 115200 serial 2 16384 115200 57600 0 115200 serial 3 64 115200 57600 0 115200 serial 5 0 115200 57600 0 115200 serial 6 0 115200 57600 0 115200 # led led 0 5,3::C:8 led 1 5,4::C:8 led 2 5,5::C:8 led 3 7,3::C:8 led 4 7,4::C:8 led 5 7,5::C:8 # color color 5 102,0,255 # mode_color # aux aux 0 0 0 1075 1225 0 0 aux 1 1 1 1375 1625 0 0 aux 2 46 255 1300 1700 0 0 aux 3 13 255 1300 1700 0 0 aux 4 28 1 1075 1250 0 0 aux 5 35 3 1425 1600 0 0 # adjrange # rxrange # vtx # rxfail # display_name # master set acc_calibration = -118,-46,-4160 set fpv_mix_degrees = 25 set serialrx_provider = FPORT set serialrx_inverted = ON set serialrx_halfduplex = ON set motor_pwm_protocol = DSHOT1200 set align_board_roll = 180 set gps_provider = UBLOX set osd_cap_alarm = 1200 set osd_alt_alarm = 120 set osd_vbat_pos = 2434 set osd_rssi_pos = 2067 set osd_link_quality_pos = 406 set osd_anti_gravity_pos = 2054 set osd_mah_drawn_pos = 2456 set osd_gps_sats_pos = 2048 set osd_home_dir_pos = 2062 set osd_home_dist_pos = 2073 set osd_altitude_pos = 2103 set osd_warnings_pos = 14729 set osd_avg_cell_voltage_pos = 406 set osd_stat_max_dist = ON set vtx_power = 5 ###ERROR: CORRUPTED CONFIG: vtx_power = 5### # profile profile 0 set vbat_pid_gain = ON set iterm_rotation = ON set smart_feedforward = ON set p_pitch = 57 set d_pitch = 35 set p_roll = 44 set d_roll = 36 # rateprofile rateprofile 2 set thr_mid = 26 set thr_expo = 60 set roll_rc_rate = 62 set pitch_rc_rate = 62 set yaw_rc_rate = 69 set roll_expo = 50 set pitch_expo = 50 set roll_srate = 80 set pitch_srate = 80 set yaw_srate = 74 # end the command batch batch end
Above is the diff code I have and below is the CLI dump": Code: # version # Betaflight / KAKUTEF7 (KTF7) 4.0.3 Jun 1 2019 / 11:32:26 (094cfc956) MSP API: 1.41 # start the command batch batch start board_name manufacturer_id # name name - # resources resource BEEPER 1 D15 resource MOTOR 1 E09 resource MOTOR 2 E11 resource MOTOR 3 B00 resource MOTOR 4 B01 resource MOTOR 5 C09 resource MOTOR 6 A03 resource MOTOR 7 NONE resource MOTOR 8 NONE resource SERVO 1 NONE resource SERVO 2 NONE resource SERVO 3 NONE resource SERVO 4 NONE resource SERVO 5 NONE resource SERVO 6 NONE resource SERVO 7 NONE resource SERVO 8 NONE resource PPM 1 E13 resource PWM 1 NONE resource PWM 2 NONE resource PWM 3 NONE resource PWM 4 NONE resource PWM 5 NONE resource PWM 6 NONE resource PWM 7 NONE resource PWM 8 NONE resource LED_STRIP 1 D12 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 D05 resource SERIAL_TX 3 B10 resource SERIAL_TX 4 A00 resource SERIAL_TX 5 NONE resource SERIAL_TX 6 C06 resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 D06 resource SERIAL_RX 3 B11 resource SERIAL_RX 4 A01 resource SERIAL_RX 5 NONE resource SERIAL_RX 6 C07 resource SERIAL_RX 7 E07 resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE resource SERIAL_RX 12 NONE resource I2C_SCL 1 B06 resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SCL 4 NONE resource I2C_SDA 1 B07 resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource I2C_SDA 4 NONE resource LED 1 A02 resource LED 2 NONE resource LED 3 NONE resource RX_BIND 1 NONE resource RX_BIND_PLUG 1 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 NONE resource SPI_SCK 4 E02 resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 NONE resource SPI_MISO 4 E05 resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 NONE resource SPI_MOSI 4 E06 resource CAMERA_CONTROL 1 NONE resource ADC_BATT 1 C03 resource ADC_RSSI 1 C05 resource ADC_CURR 1 C02 resource ADC_EXT 1 NONE resource BARO_CS 1 NONE resource COMPASS_CS 1 NONE resource SDCARD_CS 1 A04 resource SDCARD_DETECT 1 D08 resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource USB_MSC_PIN 1 NONE resource OSD_CS 1 B12 resource GYRO_EXTI 1 E01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 E04 resource GYRO_CS 2 NONE resource USB_DETECT 1 A08 # timer timer E13 AF1 # pin E13: TIM1 CH3 (AF1) timer B00 AF2 # pin B00: TIM3 CH3 (AF2) timer B01 AF2 # pin B01: TIM3 CH4 (AF2) timer E09 AF1 # pin E09: TIM1 CH1 (AF1) timer E11 AF1 # pin E11: TIM1 CH2 (AF1) timer C09 AF3 # pin C09: TIM8 CH4 (AF3) timer A03 AF2 # pin A03: TIM5 CH4 (AF2) timer D12 AF2 # pin D12: TIM4 CH1 (AF2) # dma dma SPI_TX 1 1 # SPI_TX 1: DMA2 Stream 5 Channel 3 dma SPI_TX 2 NONE dma SPI_TX 3 NONE dma SPI_TX 4 NONE dma SPI_RX 1 NONE dma SPI_RX 2 NONE dma SPI_RX 3 NONE dma SPI_RX 4 NONE dma ADC 1 1 # ADC 1: DMA2 Stream 4 Channel 0 dma ADC 2 NONE dma ADC 3 NONE dma UART_TX 1 NONE dma UART_TX 2 NONE dma UART_TX 3 NONE dma UART_TX 4 NONE dma UART_TX 5 NONE dma UART_TX 6 NONE dma UART_TX 7 NONE dma UART_TX 8 NONE dma UART_RX 1 NONE dma UART_RX 2 NONE dma UART_RX 3 NONE dma UART_RX 4 NONE dma UART_RX 5 NONE dma UART_RX 6 NONE dma UART_RX 7 NONE dma UART_RX 8 NONE dma pin E13 1 # pin E13: DMA2 Stream 6 Channel 6 dma pin B00 0 # pin B00: DMA1 Stream 7 Channel 5 dma pin B01 0 # pin B01: DMA1 Stream 2 Channel 5 dma pin E09 2 # pin E09: DMA2 Stream 3 Channel 6 dma pin E11 1 # pin E11: DMA2 Stream 2 Channel 6 dma pin C09 0 # pin C09: DMA2 Stream 7 Channel 7 dma pin A03 0 # pin A03: DMA1 Stream 1 Channel 6 dma pin D12 0 # pin D12: DMA1 Stream 0 Channel 2 # mixer mixer QUADX mmix reset # servo servo 0 1000 2000 1500 100 -1 servo 1 1000 2000 1500 100 -1 servo 2 1000 2000 1500 100 -1 servo 3 1000 2000 1500 100 -1 servo 4 1000 2000 1500 100 -1 servo 5 1000 2000 1500 100 -1 servo 6 1000 2000 1500 100 -1 servo 7 1000 2000 1500 100 -1 # servo mix smix reset # feature feature -RX_PPM feature -INFLIGHT_ACC_CAL feature -RX_SERIAL feature -MOTOR_STOP feature -SERVO_TILT feature -SOFTSERIAL feature -GPS feature -RANGEFINDER feature -TELEMETRY feature -3D feature -RX_PARALLEL_PWM feature -RX_MSP feature -RSSI_ADC feature -LED_STRIP feature -DISPLAY feature -OSD feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE feature -RX_SPI feature -SOFTSPI feature -ESC_SENSOR feature -ANTI_GRAVITY feature -DYNAMIC_FILTER feature RX_SERIAL feature GPS feature OSD feature ANTI_GRAVITY feature DYNAMIC_FILTER # beeper beeper GYRO_CALIBRATED beeper RX_LOST beeper RX_LOST_LANDING beeper DISARMING beeper ARMING beeper ARMING_GPS_FIX beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW beeper BAT_LOW beeper GPS_STATUS beeper RX_SET beeper ACC_CALIBRATION beeper ACC_CALIBRATION_FAIL beeper READY_BEEP beeper MULTI_BEEPS beeper DISARM_REPEAT beeper ARMED beeper SYSTEM_INIT beeper ON_USB beeper BLACKBOX_ERASE beeper CRASH_FLIP beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL # beacon beacon -RX_LOST beacon -RX_SET # map map TAER1234 # serial serial 20 1 115200 57600 0 115200 serial 0 8192 115200 57600 0 115200 serial 1 2 115200 57600 0 115200 serial 2 16384 115200 57600 0 115200 serial 3 64 115200 57600 0 115200 serial 5 0 115200 57600 0 115200 serial 6 0 115200 57600 0 115200 # led led 0 5,3::C:8 led 1 5,4::C:8 led 2 5,5::C:8 led 3 7,3::C:8 led 4 7,4::C:8 led 5 7,5::C:8 led 6 0,0::C:0 led 7 0,0::C:0 led 8 0,0::C:0 led 9 0,0::C:0 led 10 0,0::C:0 led 11 0,0::C:0 led 12 0,0::C:0 led 13 0,0::C:0 led 14 0,0::C:0 led 15 0,0::C:0 led 16 0,0::C:0 led 17 0,0::C:0 led 18 0,0::C:0 led 19 0,0::C:0 led 20 0,0::C:0 led 21 0,0::C:0 led 22 0,0::C:0 led 23 0,0::C:0 led 24 0,0::C:0 led 25 0,0::C:0 led 26 0,0::C:0 led 27 0,0::C:0 led 28 0,0::C:0 led 29 0,0::C:0 led 30 0,0::C:0 led 31 0,0::C:0 # color color 0 0,0,0 color 1 0,255,255 color 2 0,0,255 color 3 30,0,255 color 4 60,0,255 color 5 102,0,255 color 6 120,0,255 color 7 150,0,255 color 8 180,0,255 color 9 210,0,255 color 10 240,0,255 color 11 270,0,255 color 12 300,0,255 color 13 330,0,255 color 14 0,0,0 color 15 0,0,0 # mode_color mode_color 0 0 1 mode_color 0 1 11 mode_color 0 2 2 mode_color 0 3 13 mode_color 0 4 10 mode_color 0 5 3 mode_color 1 0 5 mode_color 1 1 11 mode_color 1 2 3 mode_color 1 3 13 mode_color 1 4 10 mode_color 1 5 3 mode_color 2 0 10 mode_color 2 1 11 mode_color 2 2 4 mode_color 2 3 13 mode_color 2 4 10 mode_color 2 5 3 mode_color 3 0 8 mode_color 3 1 11 mode_color 3 2 4 mode_color 3 3 13 mode_color 3 4 10 mode_color 3 5 3 mode_color 4 0 7 mode_color 4 1 11 mode_color 4 2 3 mode_color 4 3 13 mode_color 4 4 10 mode_color 4 5 3 mode_color 5 0 0 mode_color 5 1 0 mode_color 5 2 0 mode_color 5 3 0 mode_color 5 4 0 mode_color 5 5 0 mode_color 6 0 6 mode_color 6 1 10 mode_color 6 2 1 mode_color 6 3 0 mode_color 6 4 0 mode_color 6 5 2 mode_color 6 6 3 mode_color 6 7 6 mode_color 6 8 0 mode_color 6 9 0 mode_color 6 10 0 mode_color 7 0 3 # aux aux 0 0 0 1075 1225 0 0 aux 1 1 1 1375 1625 0 0 aux 2 46 255 1300 1700 0 0 aux 3 13 255 1300 1700 0 0 aux 4 28 1 1075 1250 0 0 aux 5 35 3 1425 1600 0 0 aux 6 0 0 900 900 0 0 aux 7 0 0 900 900 0 0 aux 8 0 0 900 900 0 0 aux 9 0 0 900 900 0 0 aux 10 0 0 900 900 0 0 aux 11 0 0 900 900 0 0 aux 12 0 0 900 900 0 0 aux 13 0 0 900 900 0 0 aux 14 0 0 900 900 0 0 aux 15 0 0 900 900 0 0 aux 16 0 0 900 900 0 0 aux 17 0 0 900 900 0 0 aux 18 0 0 900 900 0 0 aux 19 0 0 900 900 0 0 # adjrange adjrange 0 0 0 900 900 0 0 0 0 adjrange 1 0 0 900 900 0 0 0 0 adjrange 2 0 0 900 900 0 0 0 0 adjrange 3 0 0 900 900 0 0 0 0 adjrange 4 0 0 900 900 0 0 0 0 adjrange 5 0 0 900 900 0 0 0 0 adjrange 6 0 0 900 900 0 0 0 0 adjrange 7 0 0 900 900 0 0 0 0 adjrange 8 0 0 900 900 0 0 0 0 adjrange 9 0 0 900 900 0 0 0 0 adjrange 10 0 0 900 900 0 0 0 0 adjrange 11 0 0 900 900 0 0 0 0 adjrange 12 0 0 900 900 0 0 0 0 adjrange 13 0 0 900 900 0 0 0 0 adjrange 14 0 0 900 900 0 0 0 0 adjrange 15 0 0 900 900 0 0 0 0 adjrange 16 0 0 900 900 0 0 0 0 adjrange 17 0 0 900 900 0 0 0 0 adjrange 18 0 0 900 900 0 0 0 0 adjrange 19 0 0 900 900 0 0 0 0 adjrange 20 0 0 900 900 0 0 0 0 adjrange 21 0 0 900 900 0 0 0 0 adjrange 22 0 0 900 900 0 0 0 0 adjrange 23 0 0 900 900 0 0 0 0 adjrange 24 0 0 900 900 0 0 0 0 adjrange 25 0 0 900 900 0 0 0 0 adjrange 26 0 0 900 900 0 0 0 0 adjrange 27 0 0 900 900 0 0 0 0 adjrange 28 0 0 900 900 0 0 0 0 adjrange 29 0 0 900 900 0 0 0 0 # rxrange rxrange 0 1000 2000 rxrange 1 1000 2000 rxrange 2 1000 2000 rxrange 3 1000 2000 # vtx vtx 0 0 0 0 900 900 vtx 1 0 0 0 900 900 vtx 2 0 0 0 900 900 vtx 3 0 0 0 900 900 vtx 4 0 0 0 900 900 vtx 5 0 0 0 900 900 vtx 6 0 0 0 900 900 vtx 7 0 0 0 900 900 vtx 8 0 0 0 900 900 vtx 9 0 0 0 900 900 # rxfail rxfail 0 a rxfail 1 a rxfail 2 a rxfail 3 a rxfail 4 h rxfail 5 h rxfail 6 h rxfail 7 h rxfail 8 h rxfail 9 h rxfail 10 h rxfail 11 h rxfail 12 h rxfail 13 h rxfail 14 h rxfail 15 h rxfail 16 h rxfail 17 h # display_name display_name - # master set gyro_hardware_lpf = NORMAL set gyro_sync_denom = 1 set gyro_lowpass_type = BIQUAD set gyro_lowpass_hz = 150 set gyro_lowpass2_type = PT1 set gyro_lowpass2_hz = 150 set gyro_notch1_hz = 0 set gyro_notch1_cutoff = 0 set gyro_notch2_hz = 0 set gyro_notch2_cutoff = 0 set gyro_calib_duration = 125 set gyro_calib_noise_limit = 48 set gyro_offset_yaw = 0 set gyro_overflow_detect = ALL set yaw_spin_recovery = ON set yaw_spin_threshold = 1950 set gyro_to_use = FIRST set dyn_notch_range = AUTO set dyn_notch_width_percent = 8 set dyn_notch_q = 120 set dyn_notch_min_hz = 150 set dyn_lpf_gyro_min_hz = 150 set dyn_lpf_gyro_max_hz = 450 set gyro_filter_debug_axis = ROLL set acc_hardware = AUTO set acc_lpf_hz = 10 set acc_trim_pitch = 0 set acc_trim_roll = 0 set acc_calibration = -118,-46,-4160 set align_mag = DEFAULT set mag_bustype = I2C set mag_i2c_device = 1 set mag_i2c_address = 0 set mag_spi_device = 0 set mag_hardware = AUTO set mag_declination = 0 set mag_calibration = 0,0,0 set baro_bustype = I2C set baro_spi_device = 0 set baro_i2c_device = 1 set baro_i2c_address = 0 set baro_hardware = AUTO set baro_tab_size = 21 set baro_noise_lpf = 600 set baro_cf_vel = 985 set mid_rc = 1500 set min_check = 1050 set max_check = 1900 set rssi_channel = 0 set rssi_src_frame_errors = OFF set rssi_scale = 100 set rssi_offset = 0 set rssi_invert = OFF set rc_interp = AUTO set rc_interp_ch = RPYT set rc_interp_int = 19 set rc_smoothing_type = FILTER set rc_smoothing_input_hz = 0 set rc_smoothing_derivative_hz = 0 set rc_smoothing_debug_axis = ROLL set rc_smoothing_input_type = BIQUAD set rc_smoothing_derivative_type = BIQUAD set rc_smoothing_auto_smoothness = 10 set fpv_mix_degrees = 25 set max_aux_channels = 14 set serialrx_provider = FPORT set serialrx_inverted = ON set spektrum_sat_bind = 0 set spektrum_sat_bind_autoreset = ON set airmode_start_throttle_percent = 25 set rx_min_usec = 885 set rx_max_usec = 2115 set serialrx_halfduplex = ON set adc_device = 1 set adc_vrefint_calibration = 0 set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set input_filtering_mode = OFF set blackbox_p_ratio = 32 set blackbox_device = SDCARD set blackbox_record_acc = ON set blackbox_mode = NORMAL set min_throttle = 1070 set max_throttle = 2000 set min_command = 1000 set dshot_idle_value = 550 set dshot_burst = OFF set dshot_bidir = OFF set use_unsynced_pwm = OFF set motor_pwm_protocol = DSHOT1200 set motor_pwm_rate = 480 set motor_pwm_inversion = OFF set motor_poles = 14 set thr_corr_value = 0 set thr_corr_angle = 800 set failsafe_delay = 4 set failsafe_off_delay = 10 set failsafe_throttle = 1000 set failsafe_switch_mode = STAGE1 set failsafe_throttle_low_delay = 100 set failsafe_procedure = DROP set align_board_roll = 180 set align_board_pitch = 0 set align_board_yaw = 0 set gimbal_mode = NORMAL set bat_capacity = 0 set vbat_max_cell_voltage = 430 set vbat_full_cell_voltage = 410 set vbat_min_cell_voltage = 330 set vbat_warning_cell_voltage = 350 set vbat_hysteresis = 1 set current_meter = ADC set battery_meter = ADC set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON set use_cbat_alerts = OFF set cbat_alert_percent = 10 set vbat_cutoff_percent = 100 set force_battery_cell_count = 0 set vbat_lpf_period = 30 set ibat_lpf_period = 10 set vbat_scale = 110 set vbat_divider = 10 set vbat_multiplier = 1 set ibata_scale = 400 set ibata_offset = 0 set ibatv_scale = 0 set ibatv_offset = 0 set beeper_inversion = ON set beeper_od = OFF set beeper_frequency = 0 set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF set crashflip_motor_percent = 0 set 3d_deadband_low = 1406 set 3d_deadband_high = 1514 set 3d_neutral = 1460 set 3d_deadband_throttle = 50 set 3d_limit_low = 1000 set 3d_limit_high = 2000 set 3d_switched_mode = OFF set servo_center_pulse = 1500 set servo_pwm_rate = 50 set servo_lowpass_hz = 0 set tri_unarmed_servo = ON set channel_forwarding_start = 4 set reboot_character = 82 set serial_update_rate_hz = 100 set imu_dcm_kp = 2500 set imu_dcm_ki = 0 set small_angle = 25 set auto_disarm_delay = 5 set gyro_cal_on_first_arm = OFF set gps_provider = UBLOX set gps_sbas_mode = AUTO set gps_auto_config = ON set gps_auto_baud = OFF set gps_ublox_use_galileo = OFF set gps_set_home_point_once = OFF set gps_rescue_angle = 32 set gps_rescue_initial_alt = 50 set gps_rescue_descent_dist = 200 set gps_rescue_ground_speed = 2000 set gps_rescue_throttle_p = 150 set gps_rescue_throttle_i = 20 set gps_rescue_throttle_d = 50 set gps_rescue_velocity_p = 80 set gps_rescue_velocity_i = 20 set gps_rescue_velocity_d = 15 set gps_rescue_yaw_p = 40 set gps_rescue_throttle_min = 1200 set gps_rescue_throttle_max = 1600 set gps_rescue_throttle_hover = 1280 set gps_rescue_sanity_checks = RESCUE_SANITY_ON set gps_rescue_min_sats = 8 set gps_rescue_min_dth = 100 set gps_rescue_allow_arming_without_fix = OFF set gps_rescue_use_mag = ON set deadband = 0 set yaw_deadband = 0 set yaw_control_reversed = OFF set pid_process_denom = 4 set runaway_takeoff_prevention = ON set runaway_takeoff_deactivate_delay = 500 set runaway_takeoff_deactivate_throttle_percent = 20 set thrust_linear = 0 set transient_throttle_limit = 15 set tlm_inverted = OFF set tlm_halfduplex = ON set frsky_default_lat = 0 set frsky_default_long = 0 set frsky_gps_format = 0 set frsky_unit = IMPERIAL set frsky_vfas_precision = 0 set hott_alarm_int = 5 set pid_in_tlm = OFF set report_cell_voltage = OFF set ibus_sensor = 1,2,3,0,0,0,0,0,0,0,0,0,0,0,0 set mavlink_mah_as_heading_divisor = 0 set telemetry_disabled_voltage = OFF set telemetry_disabled_current = OFF set telemetry_disabled_fuel = OFF set telemetry_disabled_mode = OFF set telemetry_disabled_acc_x = OFF set telemetry_disabled_acc_y = OFF set telemetry_disabled_acc_z = OFF set telemetry_disabled_pitch = OFF set telemetry_disabled_roll = OFF set telemetry_disabled_heading = OFF set telemetry_disabled_altitude = OFF set telemetry_disabled_vario = OFF set telemetry_disabled_lat_long = OFF set telemetry_disabled_ground_speed = OFF set telemetry_disabled_distance = OFF set telemetry_disabled_esc_current = ON set telemetry_disabled_esc_voltage = ON set telemetry_disabled_esc_rpm = ON set telemetry_disabled_esc_temperature = ON set telemetry_disabled_temperature = OFF set ledstrip_visual_beeper = OFF set ledstrip_visual_beeper_color = WHITE set ledstrip_grb_rgb = GRB set ledstrip_profile = STATUS set ledstrip_race_color = ORANGE set ledstrip_beacon_color = WHITE set ledstrip_beacon_period_ms = 500 set ledstrip_beacon_percent = 50 set ledstrip_beacon_armed_only = OFF set sdcard_detect_inverted = ON set sdcard_mode = SPI set sdcard_dma = OFF set sdcard_spi_bus = 1 set osd_units = METRIC set osd_warn_arming_disable = ON set osd_warn_batt_not_full = ON set osd_warn_batt_warning = ON set osd_warn_batt_critical = ON set osd_warn_visual_beeper = ON set osd_warn_crash_flip = ON set osd_warn_esc_fail = ON set osd_warn_core_temp = ON set osd_warn_rc_smoothing = ON set osd_warn_fail_safe = ON set osd_warn_launch_control = ON set osd_warn_no_gps_rescue = ON set osd_warn_gps_rescue_disabled = ON set osd_rssi_alarm = 20 set osd_cap_alarm = 1200 set osd_alt_alarm = 120 set osd_esc_temp_alarm = -128 set osd_esc_rpm_alarm = -1 set osd_esc_current_alarm = -1 set osd_core_temp_alarm = 70 set osd_ah_max_pit = 20 set osd_ah_max_rol = 40 set osd_ah_invert = OFF set osd_tim1 = 2560 set osd_tim2 = 2561 set osd_vbat_pos = 2434 set osd_rssi_pos = 2067 set osd_link_quality_pos = 406 set osd_tim_1_pos = 234 set osd_tim_2_pos = 234 set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 234 set osd_anti_gravity_pos = 2054 set osd_g_force_pos = 234 set osd_throttle_pos = 234 set osd_vtx_channel_pos = 234 set osd_crosshairs_pos = 205 set osd_ah_sbar_pos = 206 set osd_ah_pos = 78 set osd_current_pos = 234 set osd_mah_drawn_pos = 2456 set osd_motor_diag_pos = 234 set osd_craft_name_pos = 234 set osd_display_name_pos = 234 set osd_gps_speed_pos = 234 set osd_gps_lon_pos = 234 set osd_gps_lat_pos = 234 set osd_gps_sats_pos = 2048 set osd_home_dir_pos = 2062 set osd_home_dist_pos = 2073 set osd_flight_dist_pos = 234 set osd_compass_bar_pos = 234 set osd_altitude_pos = 2103 set osd_pid_roll_pos = 234 set osd_pid_pitch_pos = 234 set osd_pid_yaw_pos = 234 set osd_debug_pos = 234 set osd_power_pos = 234 set osd_pidrate_profile_pos = 234 set osd_warnings_pos = 14729 set osd_avg_cell_voltage_pos = 406 set osd_pit_ang_pos = 234 set osd_rol_ang_pos = 234 set osd_battery_usage_pos = 234 set osd_disarmed_pos = 234 set osd_nheading_pos = 234 set osd_nvario_pos = 234 set osd_esc_tmp_pos = 234 set osd_esc_rpm_pos = 234 set osd_rtc_date_time_pos = 234 set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234 set osd_core_temp_pos = 234 set osd_log_status_pos = 234 set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_stat_rtc_date_time = OFF set osd_stat_tim_1 = OFF set osd_stat_tim_2 = ON set osd_stat_max_spd = ON set osd_stat_max_dist = ON set osd_stat_min_batt = ON set osd_stat_endbatt = OFF set osd_stat_battery = OFF set osd_stat_min_rssi = ON set osd_stat_max_curr = ON set osd_stat_used_mah = ON set osd_stat_max_alt = OFF set osd_stat_bbox = ON set osd_stat_bb_no = ON set osd_stat_max_g_force = OFF set osd_stat_max_esc_temp = OFF set osd_stat_max_esc_rpm = OFF set osd_stat_min_link_quality = OFF set osd_stat_flight_dist = OFF set osd_stat_max_fft = OFF set osd_profile = 1 set task_statistics = ON set debug_mode = NONE set rate_6pos_switch = OFF set cpu_overclock = OFF set pwr_on_arm_grace = 5 set scheduler_optimize_rate = OFF set vtx_band = 4 set vtx_channel = 1 set vtx_power = 5 ###ERROR: CORRUPTED CONFIG: vtx_power = 5### set vtx_low_power_disarm = OFF set vtx_freq = 5740 set vtx_pit_mode_freq = 0 set vtx_halfduplex = ON set vcd_video_system = AUTO set vcd_h_offset = 0 set vcd_v_offset = 0 set max7456_clock = DEFAULT set max7456_spi_bus = 2 set max7456_preinit_opu = OFF set displayport_msp_col_adjust = 0 set displayport_msp_row_adjust = 0 set displayport_max7456_col_adjust = 0 set displayport_max7456_row_adjust = 0 set displayport_max7456_inv = OFF set displayport_max7456_blk = 0 set displayport_max7456_wht = 2 set esc_sensor_halfduplex = OFF set esc_sensor_current_offset = 0 set led_inversion = 0 set dashboard_i2c_bus = 1 set dashboard_i2c_addr = 60 set camera_control_mode = HARDWARE_PWM set camera_control_ref_voltage = 330 set camera_control_key_delay = 180 set camera_control_internal_resistance = 470 set camera_control_inverted = OFF set pinio_config = 1,1,1,1 set pinio_box = 255,255,255,255 set usb_hid_cdc = OFF set usb_msc_pin_pullup = ON set rcdevice_init_dev_attempts = 6 set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0 set rcdevice_feature = 0 set gyro_1_bustype = SPI set gyro_1_spibus = 4 set gyro_1_i2cBus = 0 set gyro_1_i2c_address = 0 set gyro_1_sensor_align = CW270 set gyro_2_bustype = SPI set gyro_2_spibus = 4 set gyro_2_i2cBus = 0 set gyro_2_i2c_address = 0 set gyro_2_sensor_align = DEFAULT set mco2_on_pc9 = OFF set timezone_offset_minutes = 0 set gyro_rpm_notch_harmonics = 3 set gyro_rpm_notch_q = 500 set gyro_rpm_notch_min = 100 set dterm_rpm_notch_harmonics = 0 set dterm_rpm_notch_q = 500 set dterm_rpm_notch_min = 100 set rpm_notch_lpf = 150 # profile profile 0 set dyn_lpf_dterm_min_hz = 150 set dyn_lpf_dterm_max_hz = 250 set dterm_lowpass_type = BIQUAD set dterm_lowpass_hz = 150 set dterm_lowpass2_type = PT1 set dterm_lowpass2_hz = 100 set dterm_notch_hz = 0 set dterm_notch_cutoff = 0 set vbat_pid_gain = ON set pid_at_min_throttle = ON set anti_gravity_mode = SMOOTH set anti_gravity_threshold = 250 set anti_gravity_gain = 5000 set feedforward_transition = 0 set acc_limit_yaw = 0 set acc_limit = 0 set crash_dthreshold = 50 set crash_gthreshold = 400 set crash_setpoint_threshold = 350 set crash_time = 500 set crash_delay = 0 set crash_recovery_angle = 10 set crash_recovery_rate = 100 set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = ON set smart_feedforward = ON set iterm_relax = RP set iterm_relax_type = SETPOINT set iterm_relax_cutoff = 20 set iterm_windup = 100 set iterm_limit = 400 set pidsum_limit = 500 set pidsum_limit_yaw = 400 set yaw_lowpass_hz = 0 set throttle_boost = 5 set throttle_boost_cutoff = 15 set acro_trainer_angle_limit = 20 set acro_trainer_lookahead_ms = 50 set acro_trainer_debug_axis = ROLL set acro_trainer_gain = 75 set p_pitch = 57 set i_pitch = 70 set d_pitch = 35 set f_pitch = 75 set p_roll = 44 set i_roll = 60 set d_roll = 36 set f_roll = 70 set p_yaw = 35 set i_yaw = 100 set d_yaw = 0 set f_yaw = 0 set angle_level_strength = 50 set horizon_level_strength = 50 set horizon_transition = 75 set level_limit = 55 set horizon_tilt_effect = 75 set horizon_tilt_expert_mode = OFF set abs_control_gain = 0 set abs_control_limit = 90 set abs_control_error_limit = 20 set abs_control_cutoff = 11 set use_integrated_yaw = OFF set integrated_yaw_relax = 200 set d_min_roll = 20 set d_min_pitch = 22 set d_min_yaw = 0 set d_min_boost_gain = 27 set d_min_advance = 20 set motor_output_limit = 100 set auto_profile_cell_count = 0 set launch_control_mode = NORMAL set launch_trigger_allow_reset = ON set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0 set launch_control_gain = 40 # rateprofile rateprofile 2 set thr_mid = 26 set thr_expo = 60 set rates_type = BETAFLIGHT set roll_rc_rate = 62 set pitch_rc_rate = 62 set yaw_rc_rate = 69 set roll_expo = 50 set pitch_expo = 50 set yaw_expo = 0 set roll_srate = 80 set pitch_srate = 80 set yaw_srate = 74 set tpa_rate = 50 set tpa_breakpoint = 1500 set tpa_mode = D set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998 set pitch_rate_limit = 1998 set yaw_rate_limit = 1998 # end the command batch batch end Write your command here. Press Tab for AutoComplete. Save to FileLoad from fileClear output historyCopy to clipboard Port utilization: D: 0% U: 0% Packet error: 0 I2C error: 4 Cycle Time: 126 CPU Load: 4
Noticed I have a Vtx error which I will look into later. I do have the r9m 2019 to clarify I just double checked the back of the module. I am just about to try your new code now (thankyou). As you said I am wired fport pin 2 on the r9mm --> T4 . Serial is on for my ports tab UART 4 and I have serial RX (Fport) selected for config. • Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 14-Jan-2020, 01:33 AM (This post was last modified: 14-Jan-2020, 04:33 AM by Tooom.) Ok tried the code and still have the same error unfortunately. Just solid green light and tx stuck on binding. Will try to get some pics you requested. I guess at this point I am considering just reflashing everything for Flex and downgrading to SPORT over FPORT. I have noticed when viewing the R9M 2019 manual that I have red LED on which indicates registration was successful (which lines up with what I am seeing on the reciever). On the manual for the r9m 2019 you can click on module options and select the power (for the HORUS) but on my xlite pro I just get an endless "waiting for TX'' when I try click on options. I'm thinking this could be related. So many variants of firmware and settings on the r9m.... Could my problems be firmware related specifically to me trying to run the xlite pro on the FULL size r9m 2019. The R9MP module was not out when I bought the full size and adaptor • Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 I noticed on the FRSKY Xlite pro firmware page the expected SD card contents is v0019 so I tried using that one. I also reflashed the transmitter with the 2019-07-23 190720 1. Perfectly support R9M Lite and R9M Lite Pro modules on both ACCESS and ACCST modes . Previously I was using the open tx companion 2.3.4 and letting it download the firmware with the noheli flexr9m settings applied. Interesting it asks for V0025 SD card when you do it this way. I double checked my SD card is formatted for FAT32. Anyway still no luck it will register but it wont bind. I get solid green light only when the transmitter is on, or solid red light when the tranmitter is off. Where I need the flashing green light for successful bind notes: still get the SD card error when starting up, even with altered firmware and matching V0019 SD card version. I can still access the SD card contents though as before. Another note: On this firmware when I go to version on the radio and then Modules / RX version it does not recognise my external module. Ugh! • Posts: 21,358 Threads: 592 Likes Received: 9,019 in 6,675 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 793 14-Jan-2020, 09:23 AM (This post was last modified: 14-Jan-2020, 09:26 AM by SnowLeopardFPV.) Don't use the OpenTX firmware from the FrSky website. Some of those are out of date or nightly development builds so you don't really know what you're getting. Always use the official releases from the OpenTX website. You will always need matching version SD Card contents to be safe, so if you get a card version warning on startup, update the card contents to the correct version. The whole FrSky ecosystem has turned into a complete nightmare. This is why so many people are now moving away to the likes of Jumper and Crossfire. Some of the new ACCESS stuff also seems to be flaky at best. I would still class it as being in beta. You might be better advised to just flash your R9M module and R9MM with the latest FLEX version of the ACCST firmware instead. You will need to explicitly flash the FPORT version of the ACCST FLEX firmware to the R9MM assuming you have wired it to the FC for FPORT. • Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 14-Jan-2020, 10:26 AM (This post was last modified: 14-Jan-2020, 11:25 AM by Tooom.) Honestly Thankyou for continuing to look at this, Im definitely going to keep trying OK I will try that, I have flashed Open Tx again to latest from the companion app (2.3.4). And begun my downloads again • Posts: 21,358 Threads: 592 Likes Received: 9,019 in 6,675 posts Likes Given: 1,428 Joined: Jun 2018 Reputation: 793 14-Jan-2020, 11:25 AM (This post was last modified: 14-Jan-2020, 11:25 AM by SnowLeopardFPV.) The R9M module only has one version of the FLEX firmware for ACCST, but the R9MM receiver has two versions of the FLEX firmware for ACCST - one for SBUS/S.Port, and the other for FPORT. You need to update the both the R9M module and the R9MM receiver with latest version of the FLEX ACCST firmware, making sure you use the correct SBUS/S.Port or FPORT version on the R9MM receiver. • Posts: 22 Threads: 4 Likes Received: 2 in 2 posts Likes Given: 5 Joined: Dec 2019 Reputation: 1 Thanks Snow I have tried with my R9 mini this time, I have used the Fport FCC Flex latest firmware for the Reciever as you suggested, and I used the flex R9m2019 Tx firmware, Also updated my Opentx, flashed the internal module just in case (because why not hah I now am a flashing master!) This time I get a module registration ok when using R9MLP ACCESS (wouldn't work for R9M ACCESS) However when I go for the bind nothing, solid red on the back of the TX and flashing red on the RX (indicates failsafe?). Haven't double checked outputs in betaflight yet but I am almost certain. I cannot select any of the reciever or TX options. Also on the firmware screen where you can see your ecternal module selection it hasn't recognised. What do you reckon sell up and buy a crossfire?? • |
