Help with jjpro t1
Hi I have a jjpro t1 and I have it flashed to beta flite . I can't seem to get this quad to fly good. Even on clean flite this quad is all over, anyone have any suggestions? Let me know.thanks
It's only an F1 board in these if I'm not mistaken. Betaflight might be a bit much for it. I always found Cleanflight 1.13 to be good for these little micro brushed quads.
(30-Mar-2017, 08:17 AM)unseen Wrote: ...I always found Cleanflight 1.13 to be good for these little micro brushed quads.
Of course, you probably have no need for Cleanflight Angle or Horizon self-leveling modes.  As I understand it, 1.12 through 1.14.1 all had issues in how the gyro/accel data was being used, and this led to drift problems for many people. 1.14.2 is where it appears to have finally been straightened out.
Kevin B.
Quads:
Custom 110mm FPV, NanoQX w/DX6i
Other: 3D printing (printer buildThingiverse), electronics, AVR microcontrollers
If I'm flying LOS, I'm in Horizon mode, so I'm quite familiar with the problems. They started on release 1.14.0 where a change made the Cleanflight code sample the accelerometer data at 1KHz but only filter that data at 100Hz. This lead to massive aliasing and all the fun that everyone had.
