Help with "curr"value - Telemetry Kiss FC - 24A ESC's
Hi All,
Hope someone can help me with this....: I have a question about the current ("curr") telemetry sent from the Kiss FC  to my Taranis. At 50% throttle I  am seeing current values ("curr") of approx. 10 Amps on my radio. From the thrust tests of the motor/prop setup that I have I expected to pull 10 Amps from each motor. Wouldn't that mean the "curr" value sent by the Kiss FC should be more closed to 40 Amps? Would this mean that the FC Telemetry is shown current per motor and not current total? Thanks!
I am using the below:
Kiss FC 32bit V1.03
Kiss 24A ESC's
X4R-SB
RS2205 2300 KV
DAL 5045 BN Props
Tattu 1300 70C 3S
GoPro Hero3
QAV210
All in weight: approx. 550 Gr.
do you have every ESC TLM pin connected to the KISS FC, or do you only have one?
  Flywoo AIO BF4.4.3 ESC question husafreak 4 163 03-Feb-2024, 03:32 AM
Last Post: husafreak
  Help FC wiring to different ESC brand cele_FPV 2 144 30-Jan-2024, 10:29 PM
Last Post: cele_FPV
  Help Betaflight telemetry output smartport paulno 24 1,244 05-Oct-2023, 06:23 PM
  FC to ESC wiring diagram Help oddjobsguy 4 948 01-Oct-2023, 03:30 AM
Last Post: oddjobsguy
  After flashing the ESC using JESC zomer 1 174 18-Sep-2023, 09:50 AM
Last Post: voodoo614
