Help with Brushed Quad
Hi All
I have almost finished a new brushed build but am having some issues. As soon as I plug in the battery, the motors spin up and then very slowly slow down. If I then arm the quad and throttle up, the motors increase accordingly but as soon as I set the throttle to zero again, the motors very gradually decrease throttle. My components are as follows:
Mini F3 FC: http://www.banggood.com/Mini-F3-Flight-C...21113.html
Afromini Brushed ESC: http://www.dronejunkie.co.uk/product/afr...ushed-esc/
0820 15 brushed motors.
The FC is loaded with cleanflight 1.11 and I have the following settings:
Min Throttle: 1000
Max Throttle: 2000
Looptime: 1000
Motor PWM Rate: 32kHz
Can anyone point me in the right direction for what might be causing the issue?
Regards
Jeremy
can you test the motors with the motor tab in cleanflight? if it does the something then you know it's not software or settings, it's hardware related...
Hi Oscar
Yes it does the same thing in the motors tab. It has been suggested that the FET's are not switching off. So I will have to get my multimeter out and check the resistors to see if everything is at the correct voltage.
Make sure oneshot125 is turned off, had that problem with an oskie build, and that is normally the cause (motor pwm & oneshot).
  CLI Dump for HGLRC Drashark 1S 1.6inch Micro Quad Oscar 1 601 23-Apr-2024, 08:08 PM
Last Post: segler999
  Build resource remapping on brushed betafpv brushed board Firstcoastfpv 4 157 14-Mar-2024, 03:14 PM
Last Post: iFly4rotors
  Build Low profile 3 inch prototype quad design ph2t 24 749 11-Mar-2024, 03:53 PM
Last Post: skywanderer
  Help Micro Quad flying easy but wobbling Harry1 46 1,401 13-Feb-2024, 10:18 PM
  Discussion Walksnail Avatar Goggles & Quad Combo (Axisflying Cineon Z25) QuadFlyer68 108 7,129 23-Dec-2023, 01:10 AM
Last Post: lyoha
