Threads: 17
Likes Received: 9 in 6 posts
Likes Given: 4
2 Ok I got my new Bat QX105 now what the hell do I do?
I thought I download Betaflight software but find it's a stupid Chrome App so had to go install a browser I hate so I could manage the Quad. Especially with Chrome fatal flaws where someone can take over whole system if it's open and idle.. ugg..
Anyway what now? It doesn't connect when I hit connect on default. It just talks about flashing firmware.
I can not seem to find a video on first time use of the Betaflight software on how to use it to connect to drone. Help I am lost now.
Threads: 30
Likes Given: 714
45 Are you connecting to your computer with the USB cable that came with the Bat? Is so, that would be your problem as it's only a charging cable, not data transfer
Threads: 30
Likes Given: 714
45 Don't know, just enable serial rx on uart 2 and hopefully you'll be OK
Threads: 17
Likes Given: 4
2 17-Feb-2017, 08:23 AM (This post was last modified: 17-Feb-2017, 08:59 AM by molitar.) Ok finally got it setup.. The info was in the manual and I had to configure the channels like it said. I took it for a 2 minute test flight.. damn I need to turn down the roll and pitch as it moves too fast in one direction right now.. too sensitive for me.. I barely barely move the sticks and it shooting off.
What settings do I need to change this?
BTW this thing has severe power! I held it in my hand and revved it up to verify throttle was going up smooth.. big mistake.. a propeller disappeared and one of the motors was almost completely out of the motor mount.. Wow! This quad has power!
Threads: 50
Likes Received: 704 in 450 posts
Likes Given: 1,189
30 Rc_rate and expo for mid-stick feel. The other (s)rate is for adjusting full stick rates.
If your computer runs well enough, you can use the realtime graphic display to get an impression.
Threads: 0
Likes Received: 2 in 2 posts
Likes Given: 0
0 Does anyone have any example settings to start out with for the QX105? as mentioned above, its really twitchy with the stock settings and its all I can do not to crash with the slightest roll!
