Threads: 2
Likes Received: 4 in 3 posts
Likes Given: 0
0 Hello all:
I am running Betaflight on an f3 board. I connected the Vbat inputs on the FC to the VCC and GND outputs on my Matek PDB.
When I connect a battery and connect Betaflight it appears to be showing the correct voltage on my computer. However, using my Taranis X7 with telemetry when I detect sensors and create a VBAT sensor, it shows the voltage as much lower (around 10 volts).
First, why would there be a discrepency between the Betaflight indicated voltage and the telemetry voltage indicated from telemetry? Shouldn't they be the same thing?
Second, any help with moving forward would be much appreciated.
My goal is to use logical switches and telemetry to have audible voltage warnings.
Thanks so much, Steve.
Threads: 2
Likes Received: 32 in 22 posts
Likes Given: 1
0 Hi Steve.
Its a matter for calibrating it yourself.
You should think of it as separate things, you have the voltage sensor reporting with a certain value.
This value has nothing to do with volts, i believe the way it works is that the software check how long to takes to charge a certain capacitor and relate this to how long it would take to charge it with 5v.
Whatever your Taranis displays or whatever Betaflight shows is derived from this value and is displayed in volts.
So yes, plug in the battery and check what the actual voltage is with a multi-meter.
Adjust the voltage scale if needed in betaflight with voltage scale. (Though, the default value should not be off by much)
Then adjust the ratio on your Taranis the same way.
For good measure, test it with a full, half emptry and "empty" Lipo and verify that the whole range is correct.
Threads: 125
Likes Given: 99
388 You can't use the same UART twice. There some exceptions when you can, but in your case you should wire SBUS to UART# RX and S. Port telemetry to UART## TX.
As far as telemetry, there has been report of telemetry bug for XSR and X4RSB. If you have either of these, you should consider updating RX firmware.
Threads: 4
Likes Received: 86 in 55 posts
Likes Given: 89
5 Which RX are you using? I have the XSR and needed to flash the latest firmware before I was able to read telemetry correctly.
The bit that took me a while to figure out with the Taranis X7 was you need to flash using the port on the base (near the SD card slot), pin order was GND, 5V, S.Port (closest to SD slot).
Threads: 2
Likes Given: 0
0 Thanks much for all the advise. I do have the XSR RX. I have ordered another of that small 5 pin so I can make an adapter cable to flash the RX firmware.
I'm not giving up!!!!!
I will keep you updated after the next Amazon delivery!
Cheers, Steve
Threads: 0
Likes Received: 0 in 0 posts
Likes Given: 0
0 Guys i need help urgently. I have a flysky i6 (rebranded as longing-ly brand) transmitter and i wanted to bind it to my new bfight 210 drone. I struggled with the betaflight board, as no signal was detected by the pwm flysky reviewer on the board. I tried everything twice and suddenly the board made a whine, (coil whine ish) very softly and now when it boots it does the first noise, but repeats the esc sounds continually. My 4s lipo is at 48% 14 V and should be a problem right? I can plug the flight controller into the laptop, (into betaflight config) and then it boots with the battery. But the battery connected alone now makes me afraid, could i have broken something from simply rebooting the board a lot? I fiddled with the inputs somewhat,
Any (really any) help would be greatly appreciated as i fear i fried my board, as unlikely as it seems to ti me
Info
Bfight 210 BNF version /w AFHDS 2A reciever
Dshot 30A blheli esc
Omnibus f3 (maybe) flight controller
