Having issues with a SP Racing F3 Cant flash firmware or connect.
Hi!
Im having some serious trouble with a SP racing F3. Right out of the box, i plugged it in and while cleanflight recognised the comm port i could not connect. Tried flashing firmware to it, both with cleanflight and betaflight. No joy there. Tried running through the recovery/lost comms instructions. Always says 'could not connect to bootloader, programming failed' Still no joy.
Did a bit of googling and tried installing drivers. I have tried with the silabs drivers, the winusb drivers through zadig, still no joy. I then tried flashing the FC using flash loader demonstrator. Which is a fix i have seen work for many. But it crashes the app whenever i set my comm port, baud rate and then click next.
I am starting to think this FC is busted. But i dont want to bail on it till I know for sure.
Added note, when i connect to usb i get the power light and a bunch of flashes from the red led, which then goes out for a minute then starts flashing half second on half second off. If i put it in bootloader, i just get the power light, no red led at all, which i assume means it at least goes into bootloader?
Any help with this would be much appreciated!!
Smile
Thanks
Joe
It seems pretty non-sense but try to change your usb cable.
Try one or two more even if the one you are using works well with other equipment.
(12-Aug-2020, 10:49 AM)Maiden Flight Wrote: It seems pretty non-sense but try to change your usb cable.
Hi, Thanks for the reply!
I tried with three different usb cables. Still no joy Sad
On the pc device manager can you see the selected com port with the proper drivers installed? Do you have direct usb connection or an interface board cp210x? Try to rollback all drivers and reinstall. The red blinking seems about right.
The SpRacingF3 needs the CP210X driver. Install that and see if it connects.
[Image: mV27eIDl.png]
Tried with CP210X driver, still no joy.
(12-Aug-2020, 01:21 PM)Maiden Flight Wrote: On the pc device manager can you see the selected com port with the proper drivers installed? Do you have direct usb connection or an interface board cp210x? Try to rollback all drivers and reinstall. The red blinking seems about right.
Thanks for the reply  Smile
I just have the direct usb to the FC. Tried reinstalling the CP210x drivers still with no joy.
are you able to get the FC into bootloader mode? basically short the boot pin when you connect the USB. then try to flash the firmware.
Can you change from com6 to other com port? It is double listed on your device manager
[-] The following 1 user Likes Maiden Flight's post:
  • brobot3d
(12-Aug-2020, 09:14 PM)Maiden Flight Wrote: Can you change from com6 to other com port? It is double listed on your device manager
good catch.
(12-Aug-2020, 09:40 PM)voodoo614 Wrote: good catch.
Let's hope it solves it for brobo. The spracing f3 is still a nice board Smile
  • brobot3d
You Hero!
Great catch. I changed the com port and boom, connection. Thank you so much!!!  Smile Smile
[-] The following 1 user Likes brobot3d's post:
  • Maiden Flight
(13-Aug-2020, 08:21 AM)brobot3d Wrote: You Hero!
Nice Smile
hi broo how do i change the com3 when i plug in its show me com3 i flash and everthing but when i connect the board red light blinks normal then it blink 3 times together  then blink again and and same blinks again 3 times but not connecting
#15
Did you run the ImpulseRC driver fixer? https://impulserc.blob.core.windows.net/..._Fixer.exe
Ensure no other usb devices are connected so you are not confused with the Com ports.
Did you try a different usb cable? It has to be a data cable, not just a charging cable.
Can you show us what your Betaflight shows for the Com ports when you connect?
Shocked CAUTION: My Zeus5 F411 ES24 FC Came With the Wrong Firmware segler999 3 287 30-Mar-2024, 04:38 PM
Last Post: segler999
  BetaFPV F4 FR 2S flight controller issues. itsmerandy 30 1,817 02-Nov-2023, 09:01 AM
  Help FC troubleshooting: firmware Fido16 3 305 24-Oct-2023, 09:45 PM
Last Post: voodoo614
  Speedybee f405 v3 power issues DrR0x 16 8,098 14-Oct-2023, 03:44 AM
Last Post: angent56
  Help Facing problem installing betaflight firmware from ardupilot Prashant9316 5 540 09-Oct-2023, 08:33 AM
