Hard shake in agressive turning
I have got a tuning question, i have been fighting a tune for a month now.
i get good performance but a hard shake in aggressive turning. tried increasing D made it worse, lowered the d and better but not much change really.
i am on betaflight running rewrite, my P is conservative at 4.4/4.8 d is at 13/16. but my i term is .40 that seems to be the only way i can get it to hold position on forward flight.
I am not getting bounce back after rolls either. tpa is at 0. is it possible that the i term is the culprit, should i lower i back to .30 then really up the P to try and get it to hold position?
Add some TPA. It is the P values being too high that causes that oscillation during hard turning. TPA should help this.
Too much I will cause it to over compensate in fast turns
(08-Jun-2016, 03:03 PM)Multirotor Army Wrote: Add some TPA. It is the P values being too high that causes that oscillation during hard turning. TPA should help this.
No I is for holding.... prop wash is the relationship between P and D.
You are correct. That's the problem. It's trying too hard to hold its position at high speed. The quad will fly fine with the I a little too high until you do a fast turn. Then it starts having problems holding position. It over corrects.
for what is worth, i turned the I back to .30 and upped my P 1.0 on both axis and it felt a lot better, it was holding position fine. but the video came out worse. gonna drop the I some more to .25 and try again tomorrow.
  I Learned Something Today (The Hard Way) - Matek F405-STD 5V Rail & USB SnowLeopardFPV 8 3,275 18-Feb-2019, 05:36 PM
Last Post: Oscar
  Runcam Split 2 video cut out agressive flips gmk 5 2,298 13-Nov-2017, 03:54 PM
Last Post: raspberrypi33
