Gyro sampling / PID loop frequency
Updating my Naze32 quad with latest betaflight, but unsure of what is best:
Gyro/Pid= 2khz
Or
Gyro= 2.8khz; Pid= 1.4khz (40% cpu)
What should give a better result?
Stick to 2/2. 40% CPU can easily spike much higher in flight.. best to stay below 30%.
CPU utilization is only 6% at 2/2... So I'll stick with this
Mine is 4/4khz.   is it normally ?
[Image: 40aqGA.jpg]
(13-Sep-2016, 12:31 PM)SALİH Wrote: Mine is 4/4khz.   is it normally ?
On F303, yes. On Naze32, I'd consider that a display bug Smile
Hey again, I have more questions ! little bit hard to learn after 1 year later  !!!
I had to close acc for cpu %100, but When I disabled I didnt see Angle on mode tabs. So just airmode is active ? How can I solve this situation ? and the other question is about  CLI commands... Do I need some commands for best flying ?
now I use gyro and PID frequency, but I wonder about CLI commands as gyro_lpf= ???? and filters
If I activate, gyro and PID loop frequency 4/4 and I see cpu %100
FC CARD : FOXEER F303 (spracing F3)
BETAFLIGHT 2.9.1
[Image: PQl0DQ.jpg]
If you are a beginner, you don't really need to use CLI as betaflight configurator has most options included.
If you have accelerometer disabled, angle mode is not available since acc is the hardware that's providing information about quad orientation in all axes in relation to the ground.
Try 4/2khz and see if you fall under 40%, if not, stay at 2/2. Sorry, a might have been wrong about your board capabilities.
  • SALİH
(13-Sep-2016, 07:33 PM)Konrad Stepanajtys Wrote: If you are a beginner, you don't really need to use CLI as betaflight configurator has most options included.
If you have accelerometer disabled, angle mode is not available since acc is the hardware that's providing information about quad orientation in all axes.
with 4/2khz...
[Image: yV0EkN.jpg]
Now it should be fine. One advice - don't go too much into technicallities right now. Enjoy your flying as much as you can, get yourself comfortable in FPV to the point you are able to abandon leveling modes and go acro - then learn to fly again (not kidding). When you start to feel confident again it will start making sense to fiddle with all those settings since you'll start to notice those tiny differences in behaviour of your copter.
As said in the beginning - prioritize fun now Smile
[-] The following 2 users Like KonradS's post:
  • BigglesFPV, oyvinla
join you.... thanks...
  Avoid the updated JHEMCU GHF420AIO with the ICM42688-P Gyro Recursion 19 3,030 08-Mar-2024, 09:33 AM
Last Post: swequad
  Announcement PSA: BMI270 Gyro - Hardware / Tracking Issue SnowLeopardFPV 25 1,008 07-Feb-2024, 02:39 PM
Last Post: Luk5569
  Gyro Filteration marv23 5 230 16-Jan-2024, 12:53 PM
Last Post: marv23
  Help Replace ICM gyro with BMI270 romangpro 0 164 06-Dec-2023, 11:56 AM
Last Post: romangpro
  something causes my PID loop to freak out benoitd 8 213 25-Nov-2023, 03:17 PM
Last Post: benoitd
