Threads: 25
Likes Received: 8 in 6 posts
Likes Given: 3
1 Updating my Naze32 quad with latest betaflight, but unsure of what is best:
Gyro/Pid= 2khz
Or
Gyro= 2.8khz; Pid= 1.4khz (40% cpu)
What should give a better result?
Threads: 24
Likes Received: 6 in 5 posts
Likes Given: 3
1 Stick to 2/2. 40% CPU can easily spike much higher in flight.. best to stay below 30%.
Threads: 25
Likes Given: 3
1 CPU utilization is only 6% at 2/2... So I'll stick with this
Threads: 70
Likes Received: 742 in 378 posts
Likes Given: 577
44 13-Sep-2016, 07:33 PM (This post was last modified: 13-Sep-2016, 07:54 PM by KonradS. Edit Reason: mistake ) If you are a beginner, you don't really need to use CLI as betaflight configurator has most options included.
If you have accelerometer disabled, angle mode is not available since acc is the hardware that's providing information about quad orientation in all axes in relation to the ground.
Try 4/2khz and see if you fall under 40%, if not, stay at 2/2. Sorry, a might have been wrong about your board capabilities.
