Guys need help in soldering for dys f4 pro
I dont know how to make my battery voltage to be displayed.
I use dys f4 pro
when i connect to betaflight i couldnt able to get voltage of my battery status.So help me with where should i solder.
thanks
In BetaFlight, do you have "Onboard ADC" selected under "Power & Battery"?
If it is, try saving the settings again. Make sure the FC reboots after the save by checking the log at the top. (click "Show Log" - Top right)
If my post helped you...hit the RATE button.
[-] The following 1 user Likes xcalibur's post:
  • Oscar
yeah done
as you said but still i coudnt see the bat voltage
Are you powering the board directly from the LiPo, or are you supplying power via a 4in1 ESC?
As far as I can establish you need a direct connection from the FC to the battery for it to read the battery voltage.
Can you post a photo of your setup?
Stupid question, but do you have the flight battery connected when you are looking at this in the configurator?
I had problems with DYS before and voltage. Read jflyer post. It worked for me.
https://github.com/betaflight/betaflight/issues/3804
(11-Jan-2018, 02:39 PM)xcalibur Wrote: Are you powering the board directly from the LiPo, or are you supplying power via a 4in1 ESC?
Attached Files Thumbnail(s)
Actually i used a pdb for powering esc and a connection from pdb to fc.
Also just check the picture even the battery is connected it shows not connected
and one more thing i didnt understood is what is bat+ in dys f4 diagram.
Photo of the PDB wiring to the FC, and please confirm that the battery IS connected when using the configurator?
Did you tried what I suggested? It works.
(12-Jan-2018, 06:33 AM)kalyan Wrote: Actually i used a pdb for powering esc and a connection from pdb to fc.
Have you used a regulated 5v out from the PDB to the FC? If the FC is not receiving battery voltage it will not know what the battery voltage is, to display it.
I'm pretty sure that the Bat + (on the LED and FPV connection points) is to provide battery voltage to peripherals that require more than 5v, such as some VTX. However to output battery voltage will require that the FC is powered by direct LiPo voltage, rather than a regulated voltage from the PDB.
 If you can take a photo of the wiring it might help, also if you can provide a link to the FC you bought..?
(12-Jan-2018, 06:33 AM)Tom BD Bad Wrote: Photo of the PDB wiring to the FC, and please confirm that the battery IS connected when using the configurator?
+1.
Having a photo of how you soldered the FC, PDB etc. will answer a lot of our questions.
No it didnt
(12-Jan-2018, 07:14 AM)voodoo614 Wrote: Did you tried what I suggested? It works.
okay i will dismantle it and will text you soon
(12-Jan-2018, 07:54 AM)xcalibur Wrote: +1.
Will send you the pic of wiring soon
here is the link of fc
https://oscarliang.com/dys-f4-fc/
(12-Jan-2018, 07:42 AM)Tom BD Bad Wrote: Have you used a regulated 5v out from the PDB to the FC? If the FC is not receiving battery voltage it will not know what the battery voltage is, to display it.
[-] The following 1 user Likes kalyan's post:
  • sirdude
#15
I'm confused, why are you using a PDB? The FC is AIO PDB & BEC, adding another PDB seems like its just dead weight?
[-] The following 2 users Like Tom BD Bad's post:
  • sirdude, unseen
  GOKU F722 PRO V2 50A BLS 30X30 Stack (MPU6000) husafreak 2 149 03-Mar-2024, 05:09 PM
Last Post: husafreak
  Semi Newbie here - T-Motor F7 Pro Full Function Tonestire 9 1,393 19-Feb-2024, 07:23 AM
Last Post: MontyFPV
  CRAZYBEE F4 PRO doe not get to DFU mode orangu 8 3,471 08-Aug-2023, 09:46 PM
Last Post: zomer
  Help T-Motor F7 Pro - Reciever priority (DJI) tfr33 4 526 01-Jul-2023, 08:30 PM
Last Post: Lemonyleprosy
  CRAZYBEE F4 PRO v1 receiver mode r1cksanch3z 1 237 28-May-2023, 04:06 PM
Last Post: matt0725
