GOT TO BE A BETTER WAY !!!!!
There's gotta be a better way !!!!!!!After thinking I had this battle licked  the XM plus receiver crashed    so I started over with a new receiver this time I used an X4R-SB...  Went to open TX and downloaded the new firmware flash it on to the receiver.. Downloaded it to the SD card But I still can't get this damn thing to bind please tell me what I'm doing wrong !!!!is there something else that needs to be downloaded to the receiver ?????Or is there some steps I am missing HEEEEEEEELLLLLLP !!!! Huh
Why are you getting firmware from OpenTX for X4R-SB?
https://www.frsky-rc.com/x4rsb/
If you were doing this with your XM+, maybe that is why you couldn't get it to work.
Here is the firmware for XM+
https://www.frsky-rc.com/xm-plus-mini-sb...ull-range/
It also bears pointing out that all receivers come with the correct firmware already flashed to them.
Unless you have a very good reason to flash a receiver (like encountering a known bug), then you should leave well alone. The same applies to ESCs.
(31-Dec-2017, 02:51 AM)voodoo614 Wrote: Why are you getting firmware from OpenTX for X4R-SB?
sorry i did say that wrong !!! i got the firmware from frsky for both of the receivers. and flashed both of the receivers...  was i NOT suppose to ?? all the videos ive been watching are saying to flash the receiver. then bind to the radio... can u just bind them right out of the pkg ????  AND NOW for some reason the FC wont connect to the BETA FLIGHT... is there a STEP by STEP guide or rule of thumb on things to do in order when building a drone !!! i have flown and build may RC planes.  b ut have never set up from scratch.  ( AS YOU CAN TELL). lol but its a learning curve and once i learn it i'l master it but its the from here to there THANG thats fck'n kill'n me !!!  ahah
(31-Dec-2017, 12:37 PM)unseen Wrote: It also bears pointing out that all receivers come with the correct firmware already flashed to them.
sorry i did say that wrong !!! i got the firmware from frsky for both of the receivers. and flashed both of the receivers...  was i NOT suppose to ?? all the videos ive been watching are saying to flash the receiver. then bind to the radio... can u just bind them right out of the pkg ????  AND NOW for some reason the FC wont connect to the BETA FLIGHT... is there a STEP by STEP guide or rule of thumb on things to do in order when building a drone !!! i have flown and build may RC planes.  but have never set up from scratch.  ( AS YOU CAN TELL). lol but its a learning curve and once i learn it i'l master it but its the from here to there THANG thats fck'n kill'n me !!!  ahah
(31-Dec-2017, 01:30 PM)JD Quad Jammer Wrote: can u just bind them right out of the pkg ????
Yes!
I've never flashed a receiver, FrSky or otherwise. Just wire it up, bind and go!
In fact, what I normally do is just connect power to the receiver from my bench supply and get it bound before I even install it. Most of the time, things like bind buttons tend to become hard to get at once the receiver is installed in the quad, so binding the radio and receiver ahead of the build lets me check that the receiver is working before I commit to installing it.
  • kaitylynn
(31-Dec-2017, 01:48 PM)unseen Wrote: Yes!
OK...  well then something else is WRONG !!!  i just took a fresh receiver same one X4R-SB  and tried to bind it ..  nothing....while trying to bind the red and green light stay on steady !!!!  no flashing.... if i plug the lipo in without holding the FS button red flashes ????????  can i bind by plugging into the smart port on the bottom of the TX ????
Binding is between the radio parts of the radio and the receiver.
If you turn off the radio and connect power to the receiver while holding down the button on the receiver, the green LED should be on and the red LED should flash. Does it do that?
It is the same for all of the FrSky RX I have ever used, regardless of model.
Turn on radio, create or select model, put that model in to [BND].
On the RX, hold the BIND button down and, with a 5vdc supply, power the RX.  Multiple RX having the same issue is just not likely, so either OE or something is wrong in the radio.
SoCal Kaity :D
[-] The following 1 user Likes kaitylynn's post:
  • unseen
(31-Dec-2017, 02:34 PM)unseen Wrote: Binding is between the radio parts of the radio and the receiver.
No it does not when I hold the FS button and power up both lights green and red are steady
(31-Dec-2017, 03:11 PM)JD Quad Jammer Wrote: No it does not when I hold the FS button and power up both lights green and red are steady
Bizarre. I can't find anything in the documentation that defines both LEDs being on steady as valid.
Something is wrong here. This is a genuine FrSky receiver? Do you have anything else connected at the time? What are you powering the receiver with?
Hi
I use the xr4 sb receiver and had terrible problems getting it to bind to my tarranis tx. I eventually sussed it as it needed the euro LBT firmware flash .
I was using the plain euro firmware and it just wouldnt bind but the Euro LBT worked right away.
New to this but it might help if you are having binding problems with euro tranmitter and your receiver.
Your problem is very similar to the one i sorted
https://www.frsky-rc.com/x4r/
above is link then open firmware section
You want the second download LBT,
I used my transmitter to flash the receiver
Make sure your transmitter has the euro firmware too, flashing TX and Rx is easy as long as you follow instuctions and make sure transmitter battery has plenty of power before you start
(31-Dec-2017, 05:17 PM)unseen Wrote: Bizarre. I can't find anything in the documentation that defines both LEDs being on steady as valid.
yes they are genuine .. i even have a second one and tried it !!!  SAME THANG......  im lost
Try euro lbt firmware
#15
(31-Dec-2017, 08:33 PM)Droning Martyn Wrote: Try euro lbt firmware
how can i tell if euro is on my transmitter  my Qx7
