31-May-2021, 02:49 AM
Hello All!
I'm Chasing an issue with my 5" quad. It's a readytosky kt230 frame (like umagawd remix) running 6s, 1999kv iflight cyber motors, 45a singles iflight esc, matek f722se.
-every time I flip or roll my motors heat up by about 5 C untill the esc's are overtemp all the way to almost burning them without temp protection in bl_heli.
- same quad flew great with temps around 60-70 no higher than 80 C after the hardest flying before last crash
- this started after a crash that I thought killed motor number 1 (apparently not just motor 1) so I replaced it and the ESC... something is still happening, after a flip or roll it will lose control for a milisec and then come back and it gets worse the hotter the motors get. it's not bounceback although I do have a little (my P is a little high) it was flying great before the crash on the same pids. And to top it off I flew it on stock BF PID's and filter's and the problem was the same so i just went back to my tuned pids. It almost seems like a desync but I cant diagnose the problem and not sure where to look.
- I've attached a link for Flight video (excuse the dark rainyness gotta fly even in the rain!) blackbox log and my goggle video so you can see the esc temp rising in the osd(forgot to turn on the osd till halfway through)
- Everything on the quad "looks" good i.e. no broken arms or frayed loose wires I can see no evidence of burnt ESC or motors everything is tight, soft mounted, and lock-tighted
- ESC settings I changed are
* demag comp- high
* rampup power- 12%
* Auto timing
* Variable PWM 16-48hz
* temp protection 90 C
-link to flight video and bbl and goggle DVR
https://drive.google.com/drive/folders/1...sp=sharing
-I'll post a dump as well
-last thing I was in debug dshot rpm errors trying to figure this out so if anyone needs me to fly a different debug let me know
Thanks so much in advance!!!
* demag comp- high
* rampup power- 12%
* Auto timing
# dump
# Betaflight / STM32F7X2 (S7X2) 4.2.8 Feb 15 2021 / 12:10:35 (101738d8e) MSP API: 1.43
# config: manufacturer_id: MTKS, board_name: MATEKF722SE, version: f173f9bc, date: 2019-10-02T14:43:13Z
# start the command batch
batch start
board_name MATEKF722SE
manufacturer_id MTKS
# name: CJ0311
# resources
resource BEEPER 1 C13
resource MOTOR 1 B05
resource MOTOR 2 B04
resource MOTOR 3 B01
resource MOTOR 4 B00
resource MOTOR 5 A15
resource MOTOR 6 B03
resource MOTOR 7 B06
resource MOTOR 8 B07
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A03
resource PWM 1 A02
resource PWM 2 A01
resource PWM 3 A00
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource SONAR_TRIGGER 1 NONE
resource SONAR_ECHO 1 NONE
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource I2C_SCL 1 B08
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SCL 4 NONE
resource I2C_SDA 1 B09
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource I2C_SDA 4 NONE
resource LED 1 A14
resource LED 2 A13
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource TRANSPONDER 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_SCK 4 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MISO 4 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource SPI_MOSI 4 NONE
resource CAMERA_CONTROL 1 A01
resource ADC_BATT 1 C02
resource ADC_RSSI 1 C00
resource ADC_CURR 1 C01
resource ADC_EXT 1 A04
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource COMPASS_CS 1 NONE
resource COMPASS_EXTI 1 NONE
resource SDCARD_CS 1 D02
resource SDCARD_DETECT 1 NONE
resource PINIO 1 C08
resource PINIO 2 C09
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 NONE
resource OSD_CS 1 B12
resource RX_SPI_CS 1 NONE
resource RX_SPI_EXTI 1 NONE
resource RX_SPI_BIND 1 NONE
resource RX_SPI_LED 1 NONE
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 C03
resource GYRO_CS 1 B02
resource GYRO_CS 2 C15
resource USB_DETECT 1 C14
resource VTX_POWER 1 NONE
resource VTX_CS 1 NONE
resource VTX_DATA 1 NONE
resource VTX_CLK 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer A15 AF1
# pin A15: TIM2 CH1 (AF1)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer A02 AF3
# pin A02: TIM9 CH1 (AF3)
timer A01 AF2
# pin A01: TIM5 CH2 (AF2)
timer A00 AF2
# pin A00: TIM5 CH1 (AF2)
# dma
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 0
# SPI_TX 3: DMA1 Stream 5 Channel 0
dma SPI_TX 4 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma SPI_RX 4 NONE
dma ADC 1 0
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B04 0
dma pin B05 0
dma pin B00 0
dma pin B01 0
dma pin A15 0
dma pin B03 0
dma pin B06 0
dma pin B07 0
dma pin A08 2
# pin A08: DMA2 Stream 3 Channel 6
dma pin A03 NONE
dma pin A02 NONE
dma pin A01 0
# pin A01: DMA1 Stream 4 Channel 6
dma pin A00 0
# mixer
mixer QUADX
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mixer
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature GPS
feature TELEMETRY
feature LED_STRIP
feature OSD
feature ESC_SENSOR
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
# map
map AETR1234
serial 0 2 115200 115200 0 115200
serial 2 2048 115200 57600 0 115200
serial 5 1024 115200 57600 0 115200
led 0 8,13::CTO:14
led 1 9,13::CTBW:3
led 2 10,13::CTO:14
led 3 8,7::CTO:10
led 4 7,8::CTO:10
led 5 6,9::CTO:10
led 6 5,10::CTO:10
led 7 4,11::CTO:10
led 8 3,12::CTBW:3
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 86,0,255
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1550 2100 0 0
aux 1 27 7 900 1200 0 0
aux 2 46 2 1700 2100 0 0
aux 3 13 2 1300 2100 0 0
aux 4 19 4 1300 1700 0 0
aux 5 28 5 900 1300 0 0
aux 6 35 4 1825 2100 0 0
aux 7 37 7 1800 2100 0 0
aux 8 39 5 1825 2100 0 0
aux 9 40 5 1825 2100 0 0
aux 10 47 1 900 1500 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
adjrange 0 0 3 900 2100 29 3 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable powerlevels 4
vtxtable powervalues 0 1 2 3
vtxtable powerlabels 200 400 800 160
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 h
rxfail 4 h
rxfail 5 s 1200
rxfail 6 s 1850
rxfail 8 h
rxfail 9 h
# master
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 200
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 500
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = SECOND
set dyn_notch_width_percent = 10
set dyn_notch_q = 180
set dyn_notch_min_hz = 60
set dyn_notch_max_hz = 350
set dyn_lpf_gyro_min_hz = 400
set dyn_lpf_gyro_max_hz = 1000
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set acc_calibration = 24,21,-32,1
set align_mag = CW270FLIP
set mag_align_roll = 0
set mag_align_pitch = 1800
set mag_align_yaw = 2700
set mag_bustype = I2C
set mag_i2c_device = 1
set mag_i2c_address = 0
set mag_spi_device = 0
set mag_hardware = AUTO
set mag_declination = 0
set mag_calibration = 93,58,-2
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 1
set baro_i2c_address = 0
set baro_hardware = AUTO
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_input_hz = 0
set rc_smoothing_derivative_type = PT1
set rc_smoothing_auto_smoothness = 40
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set srxl2_unit_id = 1
set srxl2_baud_fast = ON
set sbus_baud_fast = OFF
set crsf_use_rx_snr = OFF
set airmode_start_throttle_percent = 0
set serialrx_halfduplex = OFF
set rx_spi_bus = 0
set adc_device = 1
set blackbox_p_ratio = 64
set blackbox_device = SDCARD
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 400
set dshot_burst = ON
set dshot_bidir = ON
set dshot_bitbang = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_switch_mode = STAGE2
set failsafe_procedure = GPS-RESCUE
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 1550
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 179
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set beeper_dshot_beacon_tone = 5
set yaw_motors_reversed = OFF
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set small_angle = 180
set gps_provider = UBLOX
set gps_sbas_mode = WAAS
set gps_sbas_integrity = OFF
set gps_auto_config = ON
set gps_auto_baud = ON
set gps_ublox_use_galileo = ON
set gps_ublox_mode = AIRBORNE
set gps_set_home_point_once = ON
set gps_use_3d_speed = OFF
set gps_rescue_angle = 45
set gps_rescue_initial_alt = 80
set gps_rescue_descent_dist = 100
set gps_rescue_yaw_p = 40
set gps_rescue_min_sats = 7
set gps_rescue_min_dth = 100
set gps_rescue_use_mag = ON
set deadband = 4
set yaw_deadband = 5
set pid_process_denom = 1
set thrust_linear = 25
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_visual_beeper = ON
set ledstrip_visual_beeper_color = YELLOW
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set sdcard_mode = SPI
set sdcard_dma = OFF
set sdcard_spi_bus = 3
set sdio_clk_bypass = OFF
set sdio_use_cache = OFF
set sdio_use_4bit_width = OFF
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_warn_fail_safe = ON
set osd_warn_rssi = ON
set osd_warn_link_quality = ON
set osd_warn_rssi_dbm = OFF
set osd_warn_over_cap = OFF
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = -60
set osd_cap_alarm = 1550
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 1281
set osd_tim2 = 1537
set osd_vbat_pos = 14753
set osd_rssi_pos = 10241
set osd_link_quality_pos = 10273
set osd_rssi_dbm_pos = 6
set osd_tim_1_pos = 10710
set osd_tim_2_pos = 234
set osd_remaining_time_estimate_pos = 14775
set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 8406
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 14541
set osd_ah_sbar_pos = 206
set osd_ah_pos = 14414
set osd_current_pos = 234
set osd_mah_drawn_pos = 8577
set osd_motor_diag_pos = 8545
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 8439
set osd_gps_lon_pos = 10736
set osd_gps_lat_pos = 10721
set osd_gps_sats_pos = 10265
set osd_home_dir_pos = 10702
set osd_home_dist_pos = 10703
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 8618
set osd_altitude_pos = 8247
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 14665
set osd_avg_cell_voltage_pos = 417
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_battery_usage_pos = 14784
set osd_disarmed_pos = 10475
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 8599
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 8334
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = ON
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_battery = ON
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = ON
set osd_stat_bbox = OFF
set osd_stat_bb_no = ON
set osd_stat_max_esc_temp = ON
set osd_stat_max_esc_rpm = ON
set osd_stat_min_link_quality = ON
set osd_stat_flight_dist = ON
set osd_stat_max_fft = OFF
set osd_stat_total_flights = ON
set osd_stat_total_time = ON
set osd_stat_total_dist = ON
set osd_stat_min_rssi_dbm = ON
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set task_statistics = ON
set debug_mode = DSHOT_RPM_ERRORS
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 5
set vtx_channel = 7
set vtx_power = 4
set vtx_freq = 5880
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vtx_spi_bus = 0
set vcd_video_system = PAL
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set frsky_spi_autobind = OFF
set frsky_spi_tx_id = 0,0
set frsky_spi_offset = 0
set frsky_x_rx_num = 0
set led_inversion = 0
set dashboard_i2c_bus = 0
set dashboard_i2c_addr = 60
set camera_control_mode = DAC
set pinio_config = 1,1,1,1
set pinio_box = 40,41,255,255
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 0
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 1
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW270FLIP
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 1800
set gyro_2_align_yaw = 2700
set i2c1_pullup = OFF
set i2c1_overclock = ON
set i2c2_pullup = OFF
set i2c2_overclock = ON
set i2c3_pullup = OFF
set i2c3_overclock = ON
set mco2_on_pc9 = OFF
set gyro_rpm_notch_q = 800
set gyro_rpm_notch_min = 50
set dterm_rpm_notch_q = 500
set dterm_rpm_notch_min = 100
set rpm_notch_lpf = 150
set flysky_spi_tx_id = 0
set stats = OFF
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set name = CJ0311
set display_name = -
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
profile 1
# profile 1
set profile_name = -
set dyn_lpf_dterm_min_hz = 126
set dyn_lpf_dterm_max_hz = 306
set dyn_lpf_dterm_curve_expo = 6
set dterm_lowpass_type = PT1
set dterm_lowpass_hz = 150
set dterm_lowpass2_type = PT1
set dterm_lowpass2_hz = 270
set dterm_notch_hz = 165
set dterm_notch_cutoff = 80
set vbat_pid_gain = OFF
set vbat_sag_compensation = 100
set pid_at_min_throttle = ON
set anti_gravity_gain = 5000
set feedforward_transition = 70
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = ON
set iterm_relax = RPY
set iterm_relax_cutoff = 10
set iterm_windup = 75
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 40
set throttle_boost = 2
set throttle_boost_cutoff = 10
set acro_trainer_angle_limit = 10
set acro_trainer_gain = 75
set p_pitch = 78
set i_pitch = 117
set d_pitch = 44
set f_pitch = 173
set p_roll = 72
set i_roll = 111
set d_roll = 40
set f_roll = 164
set p_yaw = 77
set i_yaw = 117
set d_yaw = 0
set f_yaw = 164
set angle_level_strength = 80
set horizon_transition = 75
set level_limit = 85
set horizon_tilt_effect = 75
set abs_control_gain = 5
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 0
set d_min_pitch = 0
set d_min_yaw = 0
set d_min_boost_gain = 60
set d_min_advance = 40
set motor_output_limit = 95
set auto_profile_cell_count = 6
set launch_angle_limit = 0
set launch_control_gain = 40
set ff_interpolate_sp = AVERAGED_4
set ff_spike_limit = 50
set ff_max_rate_limit = 100
set ff_smooth_factor = 50
set ff_boost = 0
set idle_min_rpm = 30
set idle_p = 50
set idle_pid_limit = 200
set idle_max_increase = 150
set level_race_mode = OFF
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 143
set pitch_rc_rate = 143
set yaw_rc_rate = 113
set roll_expo = 20
set pitch_expo = 20
set yaw_expo = 50
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 60
set tpa_breakpoint = 1350
set tpa_mode = D
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
# end the command batch
batch end
