GEPRC THINKING P16 4K
Hi everyone,
I am trying to configure my DJI FPV Remote Controller using BetaFlight (10.9.0) on my GEPRC THINKING P16 4K. I am using the following setup:
Drone: GEPRC THINKING P16 4K
            Beta Flight FC: 4.4.3
            BetaFlight Configurator: 10.9.0
Goggles V2
            Firmware: 01.00.0607
DJI FPV REMOTE CONTROLLER
            Firmware: 01.00.0608
The problem is that I do not get stick movements on BetaFlight Configurator. Thanks for all your help.
Entering CLI Mode, type 'exit' to return, or 'help'
# Building AutoComplete Cache ... Done! #
# dump
# Betaflight / STM32F411 (S411) 4.4.3 Nov 14 2023 / 16:29:40 (738127e7e) MSP API: 1.45
# config: YES
# start the command batch
batch start
board_name GEPRCF411 manufacturer_id GEPR
# name: -
# resources
resource BEEPER 1 B02 resource MOTOR 1 B04 resource MOTOR 2 B05 resource MOTOR 3 B06 resource MOTOR 4 B07 resource MOTOR 5 B03 resource MOTOR 6 B10 resource MOTOR 7 NONE resource MOTOR 8 NONE resource LED_STRIP 1 A08 resource SERIAL_TX 1 A09 resource SERIAL_TX 2 A02 resource SERIAL_TX 3 NONE resource SERIAL_TX 4 NONE resource SERIAL_TX 5 NONE resource SERIAL_TX 6 NONE resource SERIAL_TX 7 NONE resource SERIAL_TX 8 NONE resource SERIAL_TX 9 NONE resource SERIAL_TX 10 NONE resource SERIAL_TX 11 NONE resource SERIAL_TX 12 NONE resource SERIAL_RX 1 A10 resource SERIAL_RX 2 A03 resource SERIAL_RX 3 NONE resource SERIAL_RX 4 NONE resource SERIAL_RX 5 NONE resource SERIAL_RX 6 NONE resource SERIAL_RX 7 NONE resource SERIAL_RX 8 NONE resource SERIAL_RX 9 NONE resource SERIAL_RX 10 NONE resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE resource INVERTER 1 NONE resource INVERTER 2 NONE resource INVERTER 3 NONE resource INVERTER 4 NONE resource INVERTER 5 NONE resource INVERTER 6 NONE resource INVERTER 7 NONE resource INVERTER 8 NONE resource INVERTER 9 NONE resource INVERTER 10 NONE resource INVERTER 11 NONE resource INVERTER 12 NONE resource I2C_SCL 1 NONE resource I2C_SCL 2 NONE resource I2C_SCL 3 NONE resource I2C_SDA 1 NONE resource I2C_SDA 2 NONE resource I2C_SDA 3 NONE resource LED 1 C13
resource LED 2 C14
resource LED 3 NONE resource SPI_SCK 1 A05 resource SPI_SCK 2 B13 resource SPI_SCK 3 NONE resource SPI_MISO 1 A06 resource SPI_MISO 2 B14 resource SPI_MISO 3 NONE resource SPI_MOSI 1 A07 resource SPI_MOSI 2 B15 resource SPI_MOSI 3 NONE resource ESCSERIAL 1 NONE resource ADC_BATT 1 B00 resource ADC_RSSI 1 NONE resource ADC_CURR 1 B01 resource ADC_EXT 1 NONE resource PINIO 1 NONE resource PINIO 2 NONE resource PINIO 3 NONE resource PINIO 4 NONE resource USB_MSC_PIN 1 NONE resource FLASH_CS 1 NONE resource OSD_CS 1 B12 resource GYRO_EXTI 1 A01 resource GYRO_EXTI 2 NONE resource GYRO_CS 1 A04 resource GYRO_CS 2 NONE resource USB_DETECT 1 C15 resource PULLUP 1 NONE resource PULLUP 2 NONE resource PULLUP 3 NONE resource PULLUP 4 NONE resource PULLDOWN 1 NONE resource PULLDOWN 2 NONE resource PULLDOWN 3 NONE resource PULLDOWN 4 NONE
# timer
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B10 AF1
# pin B10: TIM2 CH3 (AF1)
timer A00 AF2
# pin A00: TIM5 CH1 (AF2)
timer A02 AF2
# pin A02: TIM5 CH3 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
# ADC 1: DMA2 Stream 4 Channel 0 dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A03 NONE
dma pin B04 0
# pin B04: DMA1 Stream 4 Channel 5 dma pin B05 0
dma pin B06 0
dma pin B07 0
dma pin B03 0
dma pin B10 0
dma pin A00 0
dma pin A02 0
dma pin A08 0
feature -INFLIGHT_ACC_CAL feature -RX_SERIAL
feature -RANGEFINDER feature -TELEMETRY
feature -RX_PARALLEL_PWM feature -RX_MSP
feature -OSD
feature -CHANNEL_FORWARDING feature -TRANSPONDER feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY feature RX_SERIAL
feature SOFTSERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
serial 1 1 115200 57600 0 115200
# mixer
mixer QUADX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN beeper CAM_CONNECTION_CLOSE beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST beacon -RX_SET
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color mode_color 0 mode_color 0 mode_color 0 mode_color 0 mode_color 0 mode_color 0 mode_color 1 mode_color 1 mode_color 1 mode_color 1 mode_color 1 mode_color 1 mode_color 2 mode_color 2 mode_color 2 mode_color 2 mode_color 2 mode_color 2 mode_color 3 mode_color 3 mode_color 3 mode_color 3 mode_color 3 mode_color 3 mode_color 4 mode_color 4 mode_color 4 mode_color 4
  1. 0  1
  2. 1  11
  3. 2  2
  4. 3  13
  5. 4  10
  6. 5  3
  1. 0  5
  2. 1  11
  3. 2  3
  4. 3  13
  5. 4  10
  6. 5  3
  1. 0  10
  2. 1  11
  3. 2  4
  4. 3  13
  5. 4  10
  6. 5  3
  1. 0  8
  2. 1  11
  3. 2  4
  4. 3  13
  5. 4  10
  6. 5  3
  1. 0  7
  2. 1  11
  3. 2  3
  4. 3  13
mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color mode_color
4 4 10
4 5 3
5 0 0
5 1 0
5 2 0
5 3 0
5 4 0
5 5 0
6 0 6
6 1 10
6 2 1
6 3 0
6 4 0
6 5 2
6 6 3
6 7 6
6 8 0
6 9 0
6 10 0
7 0 3
aux 0 0 0 900 1300 0 0
aux 1 1 1 900 2100 0 0
aux 2 13 2 1700 2100 0 0
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 0
vtxtable channels 0
vtxtable powerlevels 0
vtxtable powervalues
vtxtable powerlabels
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set gyro_lpf1_type = PT1
set gyro_lpf1_static_hz = 250
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 500
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 3
set dyn_notch_q = 300
set dyn_notch_min_hz = 100
set dyn_notch_max_hz = 600
set gyro_lpf1_dyn_min_hz =
set gyro_lpf1_dyn_max_hz =
set gyro_lpf1_dyn_expo = 5
set gyro_filter_debug_axis
set acc_hardware = AUTO
set acc_lpf_hz = 25
set acc_trim_roll = 0
set acc_calibration = 0,0,0,0
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rssi_smoothing = 125
set rc_smoothing = ON
set rc_smoothing_auto_factor_throttle = 30 set rc_smoothing_setpoint_cutoff = 0
set rc_smoothing_feedforward_cutoff = 0 set rc_smoothing_throttle_cutoff = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = SBUS
set serialrx_inverted = OFF
set sbus_baud_fast = OFF
250 500
= ROLL
set airmode_start_throttle_percent = 25 set rx_min_usec = 885
set serialrx_halfduplex = OFF
set msp_override_channels_mask = 0 set adc_device = 1
set adc_tempsensor_calibration30 = 0 set adc_tempsensor_calibration110 = 0 set blackbox_sample_rate = 1/4
set blackbox_device = SERIAL
set blackbox_disable_rc = OFF
set blackbox_mode = NORMAL
set blackbox_high_resolution = OFF
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 550
set dshot_burst = AUTO
set dshot_bidir = OFF
set dshot_edt = OFF
set dshot_bitbang = OFF
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set motor_output_reordering = 0,1,2,3,4,5,6,7 set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 15
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set vbat_detect_cell_voltage = 300 set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set force_battery_cell_count = 0 set vbat_display_lpf_period = 30 set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_duration_for_warning = 0 set vbat_duration_for_critical = 0 set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion
set beeper_od = OFF
set beeper_frequency
set beeper_dshot_beacon_tone = 1 set yaw_motors_reversed = OFF
set mixer_type = LEGACY
set crashflip_motor_percent = 0 set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set serial_update_rate_hz
set small_angle = 25
set imu_process_denom = 2
set gyro_cal_on_first_arm
set gps_provider = UBLOX
set gps_sbas_mode = NONE
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_ublox_mode = AIRBORNE
set gps_ublox_use_galileo = OFF set gps_set_home_point_once = OFF set gps_use_3d_speed = OFF
set gps_sbas_integrity = OFF
set gps_rescue_min_start_dist = 15 set gps_rescue_alt_mode = MAX_ALT set gps_rescue_initial_climb = 10 set gps_rescue_ascend_rate = 750 set gps_rescue_return_alt = 30
set gps_rescue_ground_speed = 750 set gps_rescue_max_angle = 45
set gps_rescue_roll_mix = 150
set gps_rescue_pitch_cutoff = 75
= ON = 0
= 100
= OFF
set gps_rescue_descent_dist = 20
set gps_rescue_landing_alt = 4
set gps_rescue_disarm_threshold = 20
set gps_rescue_throttle_max = 1700
set gps_rescue_throttle_hover = 1275
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY set gps_rescue_min_sats = 8
set gps_rescue_throttle_p set gps_rescue_throttle_i set gps_rescue_throttle_d set gps_rescue_velocity_p set gps_rescue_velocity_i set gps_rescue_velocity_d set gps_rescue_yaw_p = 20 set deadband = 0
= 15 = 15 = 20 = 8 = 40 = 12
set yaw_deadband = 0
set pid_process_denom = 2
set runaway_takeoff_prevention
set runaway_takeoff_deactivate_throttle_percent = 20 set simplified_gyro_filter = ON
set simplified_gyro_filter_multiplier
set tlm_inverted = OFF
set tlm_halfduplex = ON
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set telemetry_disabled_ground_speed =
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
= ON
= 100
OFF
set ledstrip_brightness = 100
set osd_units = METRIC
set osd_warn_bitmask = 8191
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = -60
set osd_rsnr_alarm = 4
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_distance_alarm = 0
set osd_esc_temp_alarm = 0
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 234
set osd_rssi_pos = 234
set osd_rssi_dbm_pos = 234
set osd_rsnr_pos = 234
set osd_tim_1_pos = 234
set osd_tim_2_pos = 234
set osd_remaining_time_estimate_pos = 234 set osd_flymode_pos = 234
set osd_g_force_pos = 234
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_wh_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_pilot_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 14665
set osd_avg_cell_voltage_pos = 234 set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_up_down_reference_pos = 205 set osd_ready_mode_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_adjustment_range_pos = 234 set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_stick_overlay_left_pos = 234 set osd_stick_overlay_right_pos = 234 set osd_stick_overlay_radio_mode = 2 set osd_rate_profile_name_pos = 234 set osd_pid_profile_name_pos = 234 set osd_profile_name_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 234
set osd_aux_pos = 234
set osd_sys_goggle_voltage_pos = 234 set osd_sys_vtx_voltage_pos = 234
set osd_sys_bitrate_pos = 234
set osd_sys_delay_pos = 234
set osd_sys_distance_pos = 234
set osd_sys_lq_pos = 234
set osd_sys_goggle_dvr_pos = 234
set osd_sys_vtx_dvr_pos = 234
set osd_sys_warnings_pos = 234
set osd_sys_vtx_temp_pos = 234
set osd_sys_fan_speed_pos = 234
set osd_stat_bitmask = 14124
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_gps_sats_show_hdop
set osd_displayport_device
set osd_framerate_hz = 12
set osd_menu_background = TRANSPARENT set osd_aux_channel = 1
set osd_aux_scale = 200
set osd_aux_symbol = 65
set osd_canvas_width = 30
set osd_canvas_height = 13
  • =  OFF
  • =  AUTO
set osd_craftname_msgs = OFF set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF set cpu_overclock = 108MHZ set pwr_on_arm_grace = 5
set enable_stick_arming = OFF set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_softserial_alt = OFF
set vtx_freq = 0
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = NOMINAL
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set displayport_msp_fonts = 0,0,0,0
set displayport_msp_use_device_blink = OFF set displayport_max7456_col_adjust = 0
set led_inversion = 0
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 0
set rcdevice_init_dev_attempt_interval = 1000 set rcdevice_protocol_version = 0
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set scheduler_relax_rx = 1
set scheduler_relax_osd = 1
set serialmsp_halfduplex = OFF set timezone_offset_minutes = 0 set rpm_filter_harmonics = 3
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_fade_range_hz = 50 set rpm_filter_lpf_hz = 150
set stats_min_armed_time_s = -1 set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set craft_name = -
set pilot_name = -
set altitude_source = DEFAULT
set altitude_prefer_baro = set altitude_lpf = 300 set altitude_d_lpf = 100 set box_user_1_name = - set box_user_2_name = - set box_user_3_name = - set box_user_4_name = -
100
# profile 0
set profile_name = -
set dterm_lpf1_dyn_min_hz
set dterm_lpf1_dyn_max_hz
set dterm_lpf1_dyn_expo =
set dterm_lpf1_type = PT1
set dterm_lpf1_static_hz =
set dterm_lpf2_type = PT1
set dterm_lpf2_static_hz =
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation
set pid_at_min_throttle =
set anti_gravity_gain = 80
set anti_gravity_cutoff_hz
set anti_gravity_p_gain = 100
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_setpoint_threshold = 350 set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
= 75 = 150 5
75 150
= 0 ON
= 5
set crash_limit_yaw = 200 set crash_recovery = OFF set iterm_rotation = OFF set iterm_relax = RP
set iterm_relax_type
set iterm_relax_cutoff
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw =
set yaw_lowpass_hz = 100
set throttle_boost = 5
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 30
set d_min_pitch = 34
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set motor_output_limit = 100
set launch_trigger_throttle_percent = 20 set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 0
set feedforward_boost = 15
set dyn_idle_min_rpm = 0
set dyn_idle_p_gain = 50
SETPOINT = 15
400
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set level_race_mode = OFF
set simplified_i_gain = 100
set simplified_d_gain = 100
set simplified_pi_gain = 100
set simplified_dterm_filter_multiplier = 100 set tpa_mode = D
set tpa_rate = 65
set tpa_breakpoint = 1350
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set roll_rc_rate = 7
set pitch_rc_rate = 7
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set pitch_srate = 67
set yaw_srate = 67
set throttle_limit_type = OFF set throttle_limit_percent = 100 set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
# end the command batch
batch end
And the diff all:
# diff all
# config: YES
batch start
defaults nosave
mcu_id 004800625632500120373036 signature
# master
profile 1
profile 2
profile 3
# restore original profile selection profile 0
rateprofile 1
rateprofile 2
rateprofile 3
# restore original rateprofile selectio rateprofile 0
# save configuration
save
Unless you have rewired the Caddx Vista / Runcam Link air unit to the FC in a different way than it was supplied from the factory, you have the UARTs configured incorrectly. From the factory the SBUS wire from the Caddx Vista / Runcam Link air unit is connected to UART 2. So if you haven't changed any of the wiring, run the following commands in the CLI to set the UART configuration back to as it was originally supplied from the factory, then after the FC has rebooted check for stick movements again in the Receiver tab.
save
  • felixrib
(31-Mar-2024, 01:29 AM)SnowLeopardFPV Wrote: Unless you have rewired the Caddx Vista / Runcam Link air unit to the FC in a different way than it was supplied from the factory, you have the UARTs configured incorrectly. From the factory the SBUS wire from the Caddx Vista / Runcam Link air unit is connected to UART 2. So if you haven't changed any of the wiring, run the following commands in the CLI to set the UART configuration back to as it was originally supplied from the factory, then after the FC has rebooted check for stick movements again in the Receiver tab.
save
Thanks for the reply, SnowLeopardFPV. I have not rewired the Caddx. I have run the commands suggested and there is still no stick movements in the Receiver tab. Please, find bellow the new dump and diff all report. Thanks for the help.
Entering CLI Mode, type 'exit' to return, or 'help' #
# dump
# config: YES
batch start
# name: -
# resources
resource LED 1 C13
resource LED 2 C14
resource LED 3 NONE
# timer
timer A03 AF3
timer B04 AF2
timer B05 AF2
timer B06 AF2
timer B07 AF2
timer B03 AF1
timer B10 AF1
timer A00 AF2
timer A02 AF2
timer A08 AF1
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A03 NONE
dma pin B04 0
dma pin B05 0
dma pin B06 0
dma pin B07 0
dma pin B03 0
dma pin B10 0
dma pin A00 0
dma pin A02 0
dma pin A08 0
feature -OSD
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature RX_SERIAL
feature SOFTSERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
# mixer
mixer QUADX
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper CRASH_FLIP
# beacon
beacon -RX_LOST
beacon -RX_SET
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 0
vtxtable channels 0
# vtx
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set acc_lpf_hz = 25
set acc_calibration = -48,-6,180,1
set rssi_offset = 0
set adc_device = 1
set dshot_edt = OFF
set ibatv_scale = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set gps_rescue_throttle_p = 15
set gps_rescue_throttle_i = 15
set gps_rescue_throttle_d = 20
set gps_rescue_velocity_p = 8
set gps_rescue_velocity_i = 40
set gps_rescue_velocity_d = 12
set deadband = 0
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_ah_pos = 78
set osd_profile = 1
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_freq = 0
set craft_name = -
set pilot_name = -
set altitude_prefer_baro = 100
# profile 0
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_static_hz = 75
set vbat_sag_compensation = 0
set pid_at_min_throttle = ON
set anti_gravity_cutoff_hz = 5
set acc_limit = 0
set crash_delay = 0
set iterm_relax_cutoff = 15
set pidsum_limit_yaw = 400
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
batch end
# diff all
# config: YES
batch start
defaults nosave
signature
# master
profile 1
profile 2
profile 3
rateprofile 1
rateprofile 2
rateprofile 3
save
Hang on a minute. Are you running the 4K or HD version of the GEPRC Thinking P16? You state 4K in the subject title and the first post of this thread.
The 4K version is an analog quad so you're not going to be able to get a DJI Controller working with that because it requires the use of DJI FPV Goggles and a DJI Air Unit or Caddx Vista air unit in the quad. Only the HD version has one of those air units. The 4K version does not.
If you do have have the 4K version then you're going to have to use a different controller that supports either SBUS or CRSF depending on which version of the GEPRC Thinking P16 4K you actually bought (the SBUS or CRSF versions each have a different receiver in them).
If you have the 4K version then you're also going to need to run the following CLI commands to reconfigure UART1 for ImmersionRC Tramp (for analog VTX control from your FC)...
serial 0 8192 115200 57600 0 115200
save
  • felixrib
Thanks, SnowLeopard. I made this change and did not work. Then I changed the protocol on the goggles for normal (it was SbusFast before) and I worked. Thanks for the help.
OK, so you have the HD version and not the 4K version Smile
You really want to be running the Fast SBUS protocol for the lowest possible latency, so switch your goggles back to that mode and run the following commands in the CLI tab, then both ends will be communicating using Fast SBUS...
set sbus_baud_fast = ON
save
  • felixrib
(31-Mar-2024, 03:48 PM)SnowLeopardFPV Wrote: OK, so you have the HD version and not the 4K version Smile
save
Thanks, SnowLeopard. My problem now is that I cannot fly the quad. See the video on Youtube (https://youtube.com/shorts/Oy_JM-ALHi0?feature=share) . Any tips on what to do? Thanks for the help.
If that is a stock P16, it should come setup with props out. Make sure your props are installed correctly. You need to change your BF motor tabs setting and enable MOTOR DIRECTIONS IS REVERSED.
[-] The following 1 user Likes mstc's post:
  • felixrib
Hello Mstc, thanks for the tip... I did it as you mentioned and the quad is still fliping down as I put some throttle on. Any other suggestion? It seems that the propelers are correctly installed (the quad came all installed from factory).
Double check the board alignment and motor order. From the dump it looks the same as factory, but you can check it in BF configurator. The 3D model should rotate exactly the same as you are physically moving the drone, otherwise you may need to adjust the board alignment. For the motor order, you can spin up one by one, they should spin up according to the diagram in the motors tab and rotate in the same direction as indicated.
  • felixrib
Thanks, Mstc. I checked the motor order one by one. It seems to me that they are inverted. Then I checked the inverter motor option on BF. The result is the same on the drone as I tried to fly giving a little bit of throttle to it. Any other ideas? Thanks,
There are two things that need to be set with the motors, the direction and the order.
1) The direction needs to
   a) match exactly to the diagram - if it is props out setup (P16 default) then top left (motor 4) spins counterclockwise.
   b) your props need to be installed correctly so that they are pushing air down when spinning in this direction
2) The order needs to match the diagram as well from 1 to 4
3) Finally the board alignment should match up to the 3D model in Betaflight configuration as you pitch/roll the drone in your hand.
Maybe this will help you, or you can search for videos on how to configure Betaflight
https://youtu.be/udOHBCORSrE?t=1590
  • felixrib
Hello, Mstc. I have checked directions and all steps 1, 2 and 3 listed. All ok. It seems something else. Check the video (https://youtube.com/shorts/yXfFIlzIcDM). I hope that can help you understand. I armed the quad and did not touch the sticks on the radio controller. I just touched the drone slightly and see what has happened. Any ideas on what can it be? I will post bellow the dump and diff all just in case... Thanks for the help.
# dump
# config: YES
batch start
# name: -
# resources
resource LED 1 C13
resource LED 2 C14
resource LED 3 NONE
# timer
timer A03 AF3
timer B04 AF2
timer B05 AF2
timer B06 AF2
timer B07 AF2
timer B03 AF1
timer B10 AF1
timer A00 AF2
timer A02 AF2
timer A08 AF1
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 NONE
dma SPI_MOSI 3 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin A03 NONE
dma pin B04 0
dma pin B05 0
dma pin B06 0
dma pin B07 0
dma pin B03 0
dma pin B10 0
dma pin A00 0
dma pin A02 0
dma pin A08 0
feature -OSD
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature RX_SERIAL
feature SOFTSERIAL
feature TELEMETRY
feature OSD
feature AIRMODE
# mixer
mixer QUADX
# beeper
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper CRASH_FLIP
# beacon
beacon RX_LOST
beacon RX_SET
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 1 1 1 900 1725 0 0
aux 2 13 2 900 1300 0 0
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 0
vtxtable channels 0
# vtx
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set acc_lpf_hz = 25
set rssi_offset = 0
set adc_device = 1
set dshot_edt = OFF
set ibatv_scale = 0
set beeper_od = OFF
set yaw_motors_reversed = ON
set deadband = 0
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_ah_pos = 78
set osd_profile = 1
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_freq = 0
set craft_name = -
set pilot_name = -
profile 3
# profile 3
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
rateprofile 3
# rateprofile 3
set rateprofile_name = beginner
set thr_mid = 50
set thr_expo = 100
set roll_rc_rate = 8
set pitch_rc_rate = 8
set yaw_rc_rate = 8
set roll_expo = 85
set pitch_expo = 85
set yaw_expo = 85
set roll_srate = 75
set pitch_srate = 75
set yaw_srate = 75
set throttle_limit_type = SCALE
set throttle_limit_percent = 70
batch end
# diff all
# config: YES
batch start
defaults nosave
signature
# beacon
beacon RX_LOST
beacon RX_SET
# master
profile 1
profile 2
profile 3
profile 3
rateprofile 1
rateprofile 2
rateprofile 3
# rateprofile 3
set thr_expo = 100
set yaw_rc_rate = 8
set roll_expo = 85
set pitch_expo = 85
set yaw_expo = 85
set roll_srate = 75
set yaw_srate = 75
rateprofile 3
save
When my 2S build did exactly the same thing as in the video, I simply changed the rpm filter in the PID tab. Don't change anything else; only the rpm filter. Slide the two sliders a bit to the left from 1.0 to something like 0.8, then try to take off. That worked for me.
[-] The following 1 user Likes segler999's post:
  • felixrib
#15
If the frame is cracked or some component is loose, this could cause excessive vibrations and cause the gyro to flip out. Is this a brand new BNF and this is the factory installed BF settings? You can try as Segler suggests. If that doesn't help, did you spin up the motors one by one in Betaflight configurator? Do they each spin up smoothly and pushing a lot of air downwards (you can briefly blip the sliders)?
Also are you taking off in acro mode? If you are using angle mode, make sure you calibrate your accelerometer.
  • felixrib
  GepRC Cinelog35 Flash Firmware Issue NIKO7 3 1,473 06-Jun-2023, 10:07 PM
Last Post: Lemonyleprosy
