Threads: 2
Likes Received: 66 in 45 posts
Likes Given: 27
17 I'm getting one with my warranty replacement order from them, I hope
Threads: 15
Likes Received: 10 in 8 posts
-3 FuriousFPV has taken things seriously and I like it.
Threads: 672
Likes Given: 2,027
139 Quoting someone in our FB group regarding 18650's voltage:
You are supposed to run 18650 down to 3.0v per cell if you can put up with the buzzer in the goggles ;-) Then you would would be using the full mah rating. A work around would beusing a buck boost converter in the 18650 pack to keep the voltage up like a normal 2S lipo pack. BUT then you would probably need a buzzer in the pack for when the cells get low! Maybe fatshark could tweak the firmware for the low voltage buzzer if the goggles can run a lower voltage...
Threads: 89
Likes Received: 1,283 in 768 posts
Likes Given: 1,274
31 14-Mar-2017, 11:52 AM (This post was last modified: 14-Mar-2017, 11:53 AM by Carl.Vegas.) I'm just wondering about what looks like a legitimate balance lead... which is fine, I hate reconfiguring my charger to charge my fatshark battery anyway... but will it still power the fan? I am assuming yes. Sometimes things get a little foggy inside and having the option for the fan is a big +
Also, is it just me or does anyone else get the feeling of an old NES controller when looking at the photo?
carl.vegas
Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250
Threads: 89
Likes Given: 1,274
31 (14-Mar-2017, 02:22 PM)Oscar Wrote: yes the balance lead is for powering the fan, as well as for charging in balance mode:
T-bone did this mod long before, same concept:
http://intofpv.com/t-diy-2s-3000mah-li-i...rk-goggles
That's pretty cool... It was really problematic that I couldn't find good charging info online... heck at one point following some youtube advice I was charging my battery in nicad mode! A move that later I learned was dangerous... lol...
carl.vegas
Threads: 15
-3 Anything new about this battery?
