04-May-2017, 10:41 PM
Is it bad to spin motors to full throttle without props? I'm being told this in another post of mine, and I think that's wrong. You can run full throttle for a few seconds with no prop with no danger to the motor.
Full throttle without props, bad? |
04-May-2017, 10:41 PM Is it bad to spin motors to full throttle without props? I'm being told this in another post of mine, and I think that's wrong. You can run full throttle for a few seconds with no prop with no danger to the motor. 04-May-2017, 10:44 PM it is fine for a short time. This is not an internal combustion engine that requires a load on it. So long as your ESC can handle the rpm and the bearings are not over speeding (which is fine for the rpm we normally deal with) you are golden. They are you limitations. here is an example of a motor running at more than double the usual prop speed with no load on it. Modern esc's can handle very high rpm without de-syncing. Oh and look at the date. This was when a lot of esc's were still struggling to keep sync on 4s with a prop on. |
Discussion Props | Gyr | 1 | 96 | 01-Apr-2024, 11:03 PM Last Post: hugnosed_bat | |
Help Mobula 8 after crash motor ramp up to max with minimum throttle | johnny1234 | 7 | 910 | 31-Mar-2024, 05:43 AM Last Post: spiralthomas | |
Budget 1503-4000kv motors : 5" props on 1S? : $25 RTF drone? | mstc | 0 | 373 | 04-Dec-2023, 01:22 AM Last Post: mstc | |
speedybee BL32 50A ESC bad fimware | sam26 | 3 | 476 | 13-Nov-2023, 08:12 AM Last Post: sam26 | |
Review Damn 5 inch T-props | MomoBrut | 2 | 205 | 31-Aug-2023, 03:26 PM Last Post: MomoBrut |
