FS-I6S compatible with X4R?
I just purchased a FlySky FS-I6S transmitter and didn't realize until I received it that the included FS-IA6B receiver won't fit on my Lumenier quad. Ugh...
I'd like to use an FrSky X4R receiver instead, but I don't know if it's compatible with the FS-I6S transmitter. Does anybody know if they will play friendly with each other?
Remove the pin and case on the fs-ia6b. The x4r will not work with flysky as far as I know
Thanks! I'll try that tonight! Hopefully it fits after removing the case. If not, I'm going to get a FlySky X6B receiver instead.
(01-Feb-2017, 09:08 AM)oyvinla Wrote: Remove the pin and case on the fs-ia6b. The x4r will not work with flysky as far as I know
Is it a QAV-X by any chance? I had my challenges with this frame's lack of space, even with the FrSky XSR which is pretty small.
Anyway, as oyvinla said, the X4r won't bind to your radio, but have a look at the Flysky FS-A8S which should be compatible.
No, it's actually a QAV-210. I ended up ordering a FlySky X6B receiver instead. That should manage to squeeze in there okay. I got one of those Flightclub FPV receiver mounts that are designed to be used with a FlySky X4R receiver. The X6B is supposedly a little smaller than the X4R so it should fit.
I have no idea how you manage to fit all of your electronics on your QAV-X. Those things make my QAV-210 look outright spacious! Wink
(01-Feb-2017, 08:01 PM)tozes Wrote: Is it a QAV-X by any chance? I had my challenges with this frame's lack of space, even with the FrSky XSR which is pretty small.
[-] The following 1 user Likes solcalderon's post:
  • tozes
comes with practice... first build... how the hell can i fit all those components into such small frame (ZMR 250)
... after few more builds, just finished minimalist 112... with still few spare places to pack stuff up Smile
All the best
Grzesiek (Grisha/ Greg)
thinking about building: 450
  Need HD Android Compatible Receiver crabcrawler 2 184 02-Dec-2023, 07:47 PM
Last Post: crabcrawler
  F.Port on X4R (ACCST 1.x) badger 0 328 07-Jul-2021, 08:02 AM
Last Post: badger
  Review Replacing FlySky i6S with Radiomaster TX16s L0stB1t 4 4,003 29-Aug-2020, 03:26 PM
Last Post: L0stB1t
  Help FlySky Fs-i6s vs Turnigy Evolution MerMer21 20 4,073 10-Apr-2019, 12:46 AM
Last Post: 5zero7rc
  Realistic range with QX7 + X4R-SB? (180m with current configuration) xcalibur 27 10,240 12-Jun-2018, 10:29 AM
Last Post: Darmach
