Frysky X8R and Smartport
I am using:
Raceflight One
Skitzo FC (revolt)
Lumenier cam and vtx, No unify at this time
I am not interested in being able to manipulate the vtx, I am trying to use lua scripts to adjust pids on my taranis.
The x8r has a smartport output, and I connected it with one connection like the x4r in this article ( https://oscarliang.com/pid-vtx-settings-...aceflight/ ) ,
but it does not work. To be clear I connected the smartport output (one pin) to the appropriate place on the FC. I did not connect the positive and negative plugs located right next to it.
I am guessing the x8r may need power to the connections on that side but I cannot find any information to help. If if needs power, what is the voltage tolerance?
I may be way off base. I would appreciate any help.
Justin
If you have also connected through SBUS or PPM and you are running the red and black wire with them, then it should power up.
But the easiest check is to see if you see any leds on the X8R.
(13-Oct-2017, 05:55 PM)Dutch Drone Builder Wrote: If you have also connected through SBUS or PPM and you are running the red and black wire with them, then it should power up.
I am wired for sbus. The smartport is on the other side and has three inputs. (smartport positive and negative) I dont know what the voltage in would be if it needs to be plugged in.
I have included the manual for the x8r.
.pdf   x8rmanual.pdf (Size: 498.55 KB / Downloads: 400)
If you only wired sbus do you see then some leds on the x8r if you powered it up?
(13-Oct-2017, 07:26 PM)Dutch Drone Builder Wrote: If you only wired sbus do you see then some leds on the x8r if you powered it up?
Yes. The quad flies just fine. It needs PID tuning and I am trying to be able to tune it from the Taranis without have to stop and hook it into the laptop. I took one wire from the smartport pinout and soldered it to my revolt on the input according to the article. I went into raceflight and turned on the appropriate settings. Then I copied the lua scripts to the proper folder on the SD card for the taranis. The script runs on the Taranis. it says no VTX connected (which is true I am not using the TBS unify or any osd) and it says no RX. Thanks for your help. I am not sure I am still a beginner. But I definitely still need help.
  Solved Wizard x220s ARF with X8R receiver (rx_failsafe) C_Sagan_42 4 291 31-Oct-2022, 01:43 PM
  FrySky XM+ no input on BetaFlight klnyc 15 3,277 28-Mar-2019, 01:25 PM
  UART 1 or UART 3 for Serial Rx & Smartport? Texasgrape 9 4,977 19-Nov-2018, 08:06 PM
Last Post: voodoo614
  X4R-SD Vs X8R JD Quad Jammer 9 1,203 23-Apr-2018, 11:25 PM
  QAV250 Naze32 Rev6 - X8R / XJT Build Help JasonInSpain 17 3,646 11-Nov-2017, 09:53 AM
Last Post: unseen
