FrSky XSR RX - Radio Receiver
The new FrSky XSR is smaller than I thought it would be... I was thinking it was going to be about the size of a de-pinned X4RSB but it is definitely a bit smaller than that!
[Image: 13AvLwUl.jpg]
the antennas is about 3.5" long
Supports sbus + ppm (but why PPM when you have SBUS? Smile )
SmartPort Telemetry capable!
Available from BG:
http://www.banggood.com/FrSky-XSR-2_4GHz...01201408U4
[Image: 0hE37N1l.jpg]
Not sure yet if this RX can modified or "hack" to work with naze rev5. I'm assuming there's one that doesn't involve an inverter just like how the x4r has this mod.
Attached Files Thumbnail(s)
Well, PPM could be useful sometimes Smile
SBus requires a real UART, which you may want for something else. SmartPort telemetry for example, *also* requires a real UART. So does BlackBox if you're using an external SD Card with OpenLog.
I'm a huge fan of SBus...but even with F3 controllers, real UARTs are few and more and more things are demanding them. And if you're on an F1 board...like most folks...they're really in short supply.
So yes, PPM is very welcome, especially on micro builds
Not worth the extra money Smile The X4RSB can be just as small!
besides, I hate micro connectors like that. Any savings in boards size is lost to it. To bad they couldn't just have a few through holes to solder to with everything you need.
  TX NEW Radiomaster MT12 EdgeTX & ELRS Surface Radio V-22 1 580 02-Nov-2023, 11:22 PM
Last Post: skywanderer
  TX Frsky Horus X20 X20S X20 HD voodoo614 47 14,251 10-Oct-2022, 08:24 PM
Last Post: iFly4rotors
  ESC PSA: Switch off radio while updating ESC firmware kafie1980 0 391 07-Aug-2022, 02:46 AM
Last Post: kafie1980
  TX The Complicated Mess of FrSky ACCESS and FrSky R9 SnowLeopardFPV 145 39,912 29-Nov-2020, 08:57 PM
Last Post: Rick h
  TX Better radio than T16? The Radiomaster TX16S Oscar 13 5,388 15-Jun-2020, 08:42 PM
