Frsky Horus X12S
The newest FrSky TX is up for preorder. It looks like the quality is much higher than that of the Taranis. Astheticly, it's quite a lot like the older Horus X12D but with an updated exterior. All of the buttons, switches, sliders, and knobs are in the same places though they have been redesigned.
Description:
Brand: Frsky
Item Name: Horus
Number of Channels: 16CH / up to 32CH
Operating Voltage Range: 7~15V (2s,3s lipos acceptable)
Operating Current: 330mA maximum (both RF module and backlit on)
Operating Temperature: -10~60℃
Backlight LCD Screen: 480*272, high resolution TFT color screen
Model Memories: 60 (extendible by SD card)
Compatibility: FrSky X series, D series, L series and V8-II series receivers
It comes with a really nice case that fits the Horus perfectly.
Features:
Industrial high resolution screen (480*272), readable outdoor
All CNC gimbal with 6 ball bearings, accuracy hall sensor and extensible by stick ends
Inbuilt GPS module
Inbuilt wireless trainer system
Inbuilt 6-axis sensors (3-axis gyro and 3-axis accelerator)
Two types of aluminum panels (matt or texture)
16 channels (up to 32 channels)
Audio speech function
Full telemetry and real-time data logging
Antenna detection and SWR warning
Receiver match
Newly designed internal RF module IXJT with lower latency and higher stability
Inbuilt antenna as default, external antenna could be added (for internal RF module)
External module bay
Safe power switch with integrated strap base
Two types of trainer ports
MP3 player
Haptic feedback
NiMH batteries with inbuilt charging circuit
6 position encoder for easier flight modes switch
FrSky FrTX operation system installed as default, Open source firmware supported
The price is $499.99. Almost double the Taranis.
http://www.getfpv.com/frsky-horus-x12s-radio-2805.html
  TX Frsky Horus X20 X20S X20 HD voodoo614 47 14,280 10-Oct-2022, 08:24 PM
Last Post: iFly4rotors
  TX The Complicated Mess of FrSky ACCESS and FrSky R9 SnowLeopardFPV 145 39,968 29-Nov-2020, 08:57 PM
Last Post: Rick h
  Where can I download older FrSky firmwares? wsalopek 6 2,453 22-Apr-2020, 03:14 AM
Last Post: bffigjam
  RX FrSky Push On With ACCESS - New "Archer" Receivers SnowLeopardFPV 6 2,724 22-Nov-2019, 01:15 PM
  TX Warning regarding Horus X10 ISRM upgrade voodoo614 0 1,914 25-Oct-2019, 09:27 PM
Last Post: voodoo614
