28-Aug-2019, 03:10 AM
FRSKY D8 |
28-Aug-2019, 09:21 AM Looks like it's limited to 3.3, so you'll need to use the OpenTX software to scale it. As always, Oscar has an article (https://oscarliang.com/telemetry-frsky-taranis-d4r-ii/). Here's the bit about calibrating the voltage. Quote:A1 and A2 are the analog telemetry ports on the receiver. On D4R-II we are using A1. First we need to setup the range. The receiver’s maximum input voltage used for telemetry is 3.3V. Internal voltage divider is 4:1. Maximum voltage reading for A1 is 3.3×4=13.2. In my setup I use 13.3V as this is recommended. Detailed video on telemetry voltage calibration can be found . The ground is for dead people. 28-Aug-2019, 04:36 PM Thanks i will visit the link and watch this video. 28-Aug-2019, 07:57 PM For my 2s 300 mAh lipo i time 3.3 X 2= 6.6 i don't know how should i enter this in the QX7. And i use a multimeter my multimeter show me the Frsky D8 is putting out 5 volts i don't know how should i change the range on the Taranis QX7 because the Radio he is using is the Taranis X9D Plus. These are default settings i didn't change nothing because there is a Negitive and Positive. |
Spectrum USB programmer to update Frsky rx? | baevans11 | 8 | 277 | 23-Apr-2024, 01:24 PM Last Post: baevans11 | |
Help Frsky XM+ Firmware versions | Steak-9 | 3 | 176 | 26-Mar-2024, 01:28 PM Last Post: Steak-9 | |
Help FrSky r xsr receiver not entering bind mode | August | 1 | 129 | 05-Mar-2024, 08:49 PM Last Post: August | |
Help FrSky Archer RS to Speedybee F405V4 through F.Port | trecords | 0 | 141 | 28-Jan-2024, 09:10 PM Last Post: trecords | |
Problem with FRsky R9 900mhz | PJKMBAKER | 5 | 435 | 24-Dec-2023, 02:18 PM Last Post: PJKMBAKER |
