11-Mar-2017, 03:48 PM
Hi everyone,
I am far from being in the position of counseling anyone here,
but I'd like to quickly type down my mistakes/problems in order to have someone who reads this avoid them or have a somewhat smoother experience:
One thing I did today is (finally) opening up my Taranis and fiddling around with the throttle gimbal until it felt somewhat right. It still doesn't feel "like it should" (..and not that I could give exact indications about how that would be ), but it is much better now! My improvement in the flight simulator was immediate - I was seriously starting to doubt my coordination skills, very bad thing for a surgeon..
What I did is very simple:
Take out the batteries of the Taranis, unscrew all the screws on the back while you make sure you have all switches facing the same direction. They WILL fall out, and in case you haven't been watching, you won't know how to put the switch back in. So I put all my switches facing away from me.
I left the flat connector cable on while working on the gimbal, that was no problem. Just get the appropriate size screw driver for the gimbal screw head and the case. Those are two quite different sizes..
I took "out" the indexing of the throttle by unscrewing the one screw with a smooth section on it. The other one (..in my rc-control it was the lower one) is a thoroughly threaded screw and I guess is not meant for regulating the tension.
Screw the screw holding the indentated metal strip back until its indentation does not touch the indexed wheel any more.
In my remote, the second metal strip - which regulates the friction resistance to movement, mainly the initial resistance - was fastened way too heavily, increasing the initial resistance for movement a whole lot, thus lowering the sensitivity. In this case it does not help fidgeting w the sensitivity on the software side: Your stick is just a brute.
It's much softer now, but I can't get that initial "plop" out. I will look for some silicone grease and see if that helps..
I don't know how it is for others,
but I consider the time spent in the simulator as very important.
I have spent quite some hour in the sky with my mavic, but that's a whole different pair of shoes.. It just barely touches what steering an fpv quadcopter means, I have the feeling.
Even though my mind is longing badly for the freedom of expression which is granted by the proficiency of steering an fpv quad smoothly, and it sure is trying to push the procedures,
I just can't get around exercising the same stuff over and over again, until my fingers - all of a sudden - start to do the right thing, diligently following what my mind comes up with. "Muscle memory", as it is called here, or oculomotorical reflex loop, as it's called in physiology.
To make a long story short:
One does not have to think in order to breathe. We, meaning our bodies, breathe perfectly - not too much, not too little. Just when we're anxious, or furious, or scared - then we breathe the galloping nonsense out of our lungs. THAT is the influence of conscience. That's what is happening when we learn:
The 20% of day-active conscience has to write the routine/program for those 80% of deep conscience or animal reflexes which govern us throughout the day. (Really true, 80% of the time we don't know what we're doing, we just feel it.)
Conscience has to be able to let go of control & the written program for the reflex system to take over. This transition happens a little bit like when we're falling asleep: As a kid, I was trying to catch the moment it happens.. Result: I couldn't sleep.
We have to observe attentively,
break down movements into simple components,
exercise them one by one,
put them together and exercise some more,
and then we have to forget about the whole stuff and..
..exercise some more :-)
So long,
be & do well & gnarly flying!!
E
So long,
E
