Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 1
0 Hello Pilots,
I've got a iFlight F7 mini stack installed on a Aluminum Babyhawk R frame. Using both SBUS and F.Port protocols all seems good. Able to bind to the FrSky (R-XSR) and hover.
However, FPV video is lost (both protocols) when my Taranis X9D binds with my R-XSR (looks like no VTX attached). If I turn off the Taranis X9D, video returns.
What??? How does that happen?
Has anyone experienced this problem?
Please enlighten me.
Thanks George
Threads: 172
Likes Received: 2,287 in 1,834 posts
Likes Given: 4,737
100 this sounds like an electric circuit issue to me; if the receiver receive commands the ampdraw increase.
can you mesure the voltage of both, vtx and receiver (when you the taranis is conected and the video is lost) what voltage do you mesure on the vtx pads? how do you wire your vtx? to the 5v circuit? if it can handle the battery voltage, i would suggest use the lipoin pads to power the vtx.
the problem could be to much ampdraw from your fpv and radio gear, probably the vtx hasnt enough power after the 2,4ghz conection.
Threads: 121
Likes Received: 1,423 in 739 posts
Likes Given: 1,111
42 Telemetry receivers are known to cause video interference. I take it that your rx antennas and vtx antenna are in close proximity to each other?
If you have the receiver and vtx circuits close to each other this and contribute to the problem too.
Try separating the rx antennas from the area the vtx antenna is in. Ie: maybe move the rx up to the front of the quad and mount the rx antennas off the front arms.
Also if you can’t move the rx and vtx circuits away from each other then a grounding shield placed between them will help. This can be a piece of foil or similar metal that is connected to GND on the battery.
Hope this info helps and good luck!
ph2t.
