Threads: 3
Likes Received: 0 in 0 posts
0 27-Mar-2016, 08:57 PM (This post was last modified: 17-Apr-2016, 07:59 PM by Darius Schindler.) hi together
i crashed my LS210 yesterday. "+" cable from the cam to my naze32 PDB was cutted. I soldered my cables from VTx and the cam to the PDB one more time to get sure it is all OK. My problem is still there. The picture looks very very dark so I can see only very bright things like a TV. Is my cam damaged? Thanks for your help
LS-210 // KISS FC // KISS ESC 24A RE // RCX H2205 2633KV // CC3D NAZE32 F3 PDB // Eachine 800TVL CCD + Quanum v2 FPV Goggles // Nano-Tech 1800mAh 75C 4S // Spektrum DX6 G2 Tx // LemonRX diversity sat (short antennas)
Threads: 9
Likes Received: 9 in 4 posts
2 Most likely you fried the cam. Exact same thing happened to me last week. 12v from LEDs cut and shorted against frame. My Vtx was on the same power rail (lipo voltage). My camera would go real dark then real bright. But when I stuck in a spare camera, the picture was better but I had bad signal. So had to get a new vtx too. Where the sma connector touched the carbon frame it was scorched. Not sure if it would have saved the vtx, but I'm gonna be putting some tape between it and frame from now on.
Threads: 3
0 Thank you for your help. I ordered PZ0420M and aomway 200mW. I hope it helps. Greets Darius
Threads: 672
Likes Given: 2,030
139 28-Mar-2016, 02:17 PM (This post was last modified: 28-Mar-2016, 02:17 PM by Oscar.) Another thing you can check is resetting your Camera settings to factory default...
Threads: 3
0 With the new cam pz0420m ist everything ok
