Fport frSky r9 mini problem
Hi, I just got a new FC (mamba f722 app) and everything works except my RX.
It is binded to my qx7 taranis but it does not move in betaflight.
Please help. (Sorry for my bad english and i am a beginner in fpv)
I attached a picture of my wiring and a dumpp of my Betaflight.
Attached Files Thumbnail(s)
.txt   mydump.txt (Size: 27.14 KB / Downloads: 45)
Run the following commands in the CLI and then check for stick movements again in the Receiver tab...
set serialrx_halfduplex = OFF
save
(27-May-2022, 11:49 AM)SnowLeopardFPV Wrote: Run the following commands in the CLI and then check for stick movements again in the Receiver tab...
save
it didn’t change anything
I have no idea why Diatone insist on putting a dedicated "F.Port" pad on their F7 FC's because an F7 MCU can natively handle inverted signals on any standard TX pad. Having a dedicated "F.Port" pad just causes unnecessary confusion because no-one knows whether or not they have put a (unneeded) hardware inverter on that connection.
Because neither the original settings you had nor the updated ones I provided worked, it suggests there is a possible issue with UART5. I therefore suggest you move the F.Port wire to the TX1 pad on the FC and then run the following commands in the CLI to see if using that UART works instead.
set serialrx_provider = FPORT
set serialrx_halfduplex = ON
set serialrx_inverted = ON
save
(27-May-2022, 01:31 PM)SnowLeopardFPV Wrote: I have no idea why Diatone insist on putting a dedicated "F.Port" pad on their F7 FC's because an F7 MCU can natively handle inverted signals on any standard TX pad. Having a dedicated "F.Port" pad just causes unnecessary confusion because no-one knows whether or not they have put a (unneeded) hardware inverter on that connection.
save
It isn't working... maybe a RX issue?
Is your QX7 the ACCST or ACCESS version? And how are you binding it to the R9 Mini RX? Are you using the ACCST D16 or ACCESS protocol?
(27-May-2022, 02:15 PM)SnowLeopardFPV Wrote: Is your QX7 the ACCST or ACCESS version? And how are you binding it to the R9 Mini RX? Are you using the ACCST D16 or ACCESS protocol?
i have the ACCESS version and i used the ACCESS protocol
Have you enabled (ticked) the "F.Port" option for the receiver on your QX7? You need to do that if using the ACCESS protocol. See the following post for how to do that...
https://intofpv.com/t-r-xsr-fport-connec...#pid106590
  • Litchi
(27-May-2022, 02:34 PM)SnowLeopardFPV Wrote: Have you enabled (ticked) the "F.Port" option for the receiver on your QX7? You need to do that if using the ACCESS protocol. See the following post for how to do that...
I ve already done that
Try re-flashing the firmware on the R9M Mini to the latest version. Also make sure your R9M module is up-to-date with the latest firmware version, and make sure the ISRM module in your QX7 is flashed to the latest ISRM firmware version as well.
(27-May-2022, 02:41 PM)SnowLeopardFPV Wrote: Try re-flashing the firmware on the R9M Mini to the latest version. Also make sure your R9M module is up-to-date with the latest firmware version, and make sure the ISRM module in your QX7 is flashed to the latest ISRM firmware version as well.
The R9M mini and the R9M module are up to date but what is ISRM?
(27-May-2022, 04:36 PM)Litchi Wrote: The R9M mini and the R9M module are up to date but what is ISRM?
ISRM is the internal module used on the ACCESS version of the QX7. You can download firmware for that from the link below. The latest version as of today is v2.1.6 (dated 2021-02-03).
https://www.frsky-rc.com/taranis-q-x7-access
(27-May-2022, 08:46 PM)SnowLeopardFPV Wrote: ISRM is the internal module used on the ACCESS version of the QX7. You can download firmware for that from the link below. The latest version as of today is v2.1.6 (dated 2021-02-03).
It still doesn’t work Sad
OK, at least you are on the latest versions of all the firmware so we can rule firmware out as being a cause of the issue.
If you go to the Channel Monitor page on the LCD screen of your QX7, do you see any movements of the bars on the LCD screen when you move each of the 4 stick axis?
#15
(28-May-2022, 09:41 AM)SnowLeopardFPV Wrote: OK, at least you are on the latest versions of all the firmware so we can rule firmware out as being a cause of the issue.
yes, the axes are moving
  Spectrum USB programmer to update Frsky rx? baevans11 8 385 23-Apr-2024, 01:24 PM
Last Post: baevans11
  Help Frsky XM+ Firmware versions Steak-9 3 236 26-Mar-2024, 01:28 PM
Last Post: Steak-9
  Help FrSky r xsr receiver not entering bind mode August 1 174 05-Mar-2024, 08:49 PM
Last Post: August
  Help FrSky Archer RS to Speedybee F405V4 through F.Port trecords 0 183 28-Jan-2024, 09:10 PM
Last Post: trecords
  Help Dji o3 rc link problem. Mad35 20 929 21-Jan-2024, 02:20 PM
Last Post: Mad35
