Foxeer TM600 vtx bad signal - shielding touching electronics
Electroincs related question.
I have a Foxeer TM600 vtx which developed very bad reception and range for some unknown reason. So I read online that removing the RF shield might help because the shield might be too low and touching the electronics underneath.
I gave that a shot, and it actually worked!
Then without making any modifications to the shielding, I soldered it back on with only a few dots of solder around the shield. Then I tested it again...the bad signal and range came back!!
Now, the guy in rcgroups said he stuck some electrical tape inside the shielding. When I checked my shield, it already had something that looked like masking tape already stuck on.
Does anyone have any insight into this?
They had a first batch that had the problem like you describe, but that tape inside was added to resolve it, maybe contact the seller and arrange replacement?
I had the same problem and it turns out I was on the wrong channel. There are a few channels that are very close and you can still get clear signal nearby but your range will be reduced.
I already tested all channels. And don't forget its fine once the shield is off.
FYI, i resoldered the shield back on giving a tiny bit more space underneath. The picture is clear and clean again!!
  Problem with Foxeer reaper extreme oklidog 8 1,328 12-Apr-2024, 09:33 PM
Last Post: PrOpJuNkiE
  Help Vtx overheating battfish 3 215 04-Apr-2024, 12:05 AM
  New Product AKK Alpha 10 5.8GHz 10W VTX SnowLeopardFPV 8 336 19-Mar-2024, 05:54 PM
Last Post: Suros
  Help Random VTX frequency on power up cst3x6 7 397 27-Feb-2024, 10:16 AM
Last Post: cst3x6
  Help MO1 AIO V2.1 VTX not sending signal ThatOneGuy_ 0 158 24-Jan-2024, 09:44 PM
Last Post: ThatOneGuy_
