Foxeer Reaper + Foxeer CAT 3 + SB f405 v3 no OSD
Hi all
Im struggling to make my ESC OSD work, but I have no luck Sad
Could you please help I did most of the recommendations I found here, but no luck. I can see in goggles (DJI FPV Goggles v2 + Foxeer Wildfire Analogue) just CAT build in OSD but nothing from BF OSD(
I ran out of ideas on how to fix this so I would like to ask for help, please.
Wiring (it's a but tight, so adding schema I used):
[Image: WoAp47Al.jpg]
[Image: EjvtBlZl.jpg]
[Image: 5paFdfel.jpg]
[Image: quvQjQrl.jpg]
[Image: BPRQR3zl.jpg]
[Image: McEECQbl.jpg]
[Image: ADJgchDl.jpg]
Diff:
feature -AIRMODE
feature RSSI_ADC
serial 0 131073 115200 57600 0 115200
# beacon
beacon RX_LOST
beacon RX_SET
aux 0 0 0 1750 2075 0 0
aux 1 1 1 1425 1575 0 0
aux 2 27 2 1700 2100 0 0
aux 3 13 3 1700 2100 0 0
aux 4 28 1 1950 2100 0 0
aux 5 52 3 1425 1575 0 0
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A CUSTOM  5865 5845 5825 5805 5785 5765 5745 5725
vtxtable band 2 BOSCAM_B B CUSTOM  5733 5752 5771 5790 5809 5828 5847 5866
vtxtable band 3 BOSCAM_E E CUSTOM  5705 5685 5665 5645 5885 5905 5925 5945
vtxtable band 4 FATSHARK F CUSTOM  5740 5760 5780 5800 5820 5840 5860 5880
vtxtable band 5 RACEBAND R CUSTOM  5658 5695 5732 5769 5806 5843 5880 5917
vtxtable powerlevels 5
vtxtable powervalues 25 100 200 400 600
vtxtable powerlabels 25 200 500 1.5 2.5
# master
set dyn_notch_count = 1
set dyn_notch_q = 500
set acc_calibration = -10,-6,3,1
set blackbox_device = NONE
set dshot_bidir = ON
set failsafe_switch_mode = STAGE2
set yaw_motors_reversed = ON
set small_angle = 180
set gps_ublox_use_galileo = ON
set gps_rescue_min_start_dist = 20
set gps_rescue_ascend_rate = 600
set gps_rescue_return_alt = 40
set gps_rescue_ground_speed = 600
set gps_rescue_throttle_hover = 1200
set gps_rescue_min_sats = 5
set osd_vbat_pos = 2049
set osd_link_quality_pos = 2073
set osd_link_tx_power_pos = 2077
set osd_flymode_pos = 2433
set osd_throttle_pos = 2397
set osd_crosshairs_pos = 2382
set osd_mah_drawn_pos = 2066
set osd_craft_name_pos = 2433
set osd_gps_speed_pos = 2141
set osd_gps_lon_pos = 2244
set osd_gps_lat_pos = 2461
set osd_gps_sats_pos = 2077
set osd_home_dir_pos = 2457
set osd_home_dist_pos = 2460
set osd_flight_dist_pos = 2269
set osd_altitude_pos = 2193
set osd_warnings_pos = 14721
set osd_avg_cell_voltage_pos = 2057
set osd_battery_usage_pos = 16618
set osd_esc_tmp_pos = 2461
set osd_esc_rpm_pos = 2406
set osd_efficiency_pos = 407
set osd_aux_pos = 2081
set osd_sys_vtx_temp_pos = 2461
set osd_stat_bitmask = 343848
set osd_displayport_device = MSP
set osd_canvas_width = 30
set osd_canvas_height = 16
set vtx_band = 4
set vtx_power = 1
set vcd_video_system = PAL
set craft_name = Mosquito 2
# profile 0
set profile_name = >>>
set p_pitch = 51
set i_pitch = 60
set d_pitch = 37
set f_pitch = 137
set p_roll = 49
set i_roll = 57
set d_roll = 33
set f_roll = 132
set p_yaw = 49
set i_yaw = 57
set f_yaw = 132
set d_min_roll = 33
set d_min_pitch = 37
set simplified_master_multiplier = 110
set simplified_i_gain = 65
set simplified_dmax_gain = 0
# end the command batch
batch end
the full backup is attached
So yes in BF configuration:
- I do have enabled OSD
- I can see list of profiles in OSD configuration but cannot upload font's for some reason
- I tried pal/ntsc/
.txt   BTFL_cli_Mosquito_2_20231106_135712.txt (Size: 8 bytes / Downloads: 21)
Wiring looks correct. There is no content in the dump file. Please save a new dump and post.
Can you check the suspicious indent on the MCU?
Whatever OSD element you want to display, make sure it is not on the edge. Move it to the center just to see if it gets display. Sometime you see it in BFC but it is off the screen in real life.
Interesting that you can't upload font. Possibly error in firmware. Worth it to save a dump and try reflashing the firmware.
If all else fails, it might be the OSD chip.
thanks for a replay back
re-upload the backup
voodoo614, what do you mean by "suspicious indent on the MCU"?
thanks
voodoo614
.txt   BTFL_cli_backup_Mosquito_2_20231106_182435.txt (Size: 3.24 KB / Downloads: 30)
[Image: yxxQQeil.jpg]
Can you post a full dump? Go to CLI and type "dump". Copy everything into text file.
When you cloud built the firmware, did you include the OSD feature in the build?
so the best solution was to flash everything and start from scratch and it helps!
thanks for the support!
for future generations putting my config which works
PS regarding the cut. That's an artifact after dielectric lacquer
.txt   BTFL_cli_Mosquito_2_20231107_100337.txt (Size: 26.39 KB / Downloads: 35)
Great, you got it working.
  Help OSD Working but Grey Screen Caelus_fpv 4 145 25-Apr-2024, 03:14 PM
Last Post: Caelus_fpv
  Betaflight OSD not showing any information, but OSD menu is working gwennoyel 22 9,342 19-Apr-2024, 08:35 PM
Last Post: Maxym666
  Problem with Foxeer reaper extreme oklidog 8 1,380 12-Apr-2024, 09:33 PM
Last Post: PrOpJuNkiE
  Help OSD Not Displaying Victory FPV 11 546 20-Mar-2024, 11:43 AM
Last Post: Victory FPV
  Black video but with OSD Dexter 6 262 08-Mar-2024, 10:42 AM
Last Post: Dexter
