Foxeer Arrow V2 calibrate procedure?
In a comment on his article about the Foxeer Arrow V2 FPV cam, Oscar Liang mentioned 'calibrating' the camera in order to rectify a situation where the battery voltage display is off by a factor of 10. (My camera, like some others, displays "5.2 V" instead of "15.2 V").
Does anyone know how to actuate a re-calibration?
Thanks,
Christopher
1. make sure you are using the 'VSEN' pin is connected to your lipo battery? otherwise you will be getting the camera power supply voltage
2. make sure the voltage number is not partly hidden by the edge of the screen
Here is how to calibrate voltage:
https://oscarliang.com/ctt/uploads/2016/...nual-1.jpg
=>FPV OSD setup
=> Point 4
  Problem with Foxeer reaper extreme oklidog 8 1,334 12-Apr-2024, 09:33 PM
Last Post: PrOpJuNkiE
  Help Foxeer Reaper + Foxeer CAT 3 + SB f405 v3 no OSD AlexMM 6 550 07-Nov-2023, 10:54 AM
Last Post: voodoo614
Question Help Betaflight OSD is not working (F405v3, TX800, Foxeer T-Rex Micro) maggrave 5 1,231 20-Oct-2023, 11:17 PM
  Foxeer reaper extreme problem fearlessflyers 11 1,041 24-Jun-2023, 03:44 PM
Last Post: Bad Raven
  FOXEER Wildfire and EV300o/sky04x compatibility porlock 2 655 07-Feb-2023, 12:52 AM
Last Post: porlock
